Hello, so I was thinking about triple flamer russes and how to get them up close to the enemy.
I think you could use the Ambush stratagem to get just outside of 9", then use the Tallarn tank order to move 6" closer before firing, right? Thus you can get your flamers in range. You could also charge from just over 3" and get 3 S8 attacks hitting on 2+ with Crush Them!
Not sure if it's remotely competitive, but seems very fun. It would be very painful for the opponent to charge as well.
That should work!  But I think Hellhounds are more effective for that task.. cheaper points wise, and more useful in turns after the initial strike. The problem with flamers is you want to get the tank to move up close, whilst Russes benefit more from moving up to half range so they can double fire their main cannon..
Register a new account
Sign in
