Okay so this may seem spammy, but it is also fluffy. So the idea is both mastodons take their delicious cargo to where it’s needed and the breached squad in the land raider uses them as cover and grabs an objective.
Typhus
9 grave wardens
3x10 grave wardens
10 breathers Volkite breaching charge Melta Bomb arty armour land raider proteus/ Lascannons
2x mastodons
Should come in at 3500 using the onslaught FOC
is it too much?
Edited by Donnodouglas
The land raider will go first, along with its contents. The grave wardens will then proceed to die like chumps pretty much as soon as they disembark given the amount of firepower the opposing army will have at that points level.
The mastodons will do very little damage to the opposing army, and will, in turn, either be wrecked, turning into a very expensive set of ruins, or will survive, but not achieve much given the two of them will be your only remaining units.
Or the mastodons will blow up and almost everything inside will die.
Register a new account
Sign in
