HeresyBeliever Posted March 16, 2018 Share Posted March 16, 2018 (edited) So what are peoples thought on the Vindicator Laser destoyers vs las predators? I can see the stat differences but in game who has experience of both? I cant make up my mind which to buy Edited March 16, 2018 by HeresyBeliever Link to comment Share on other sites More sharing options...
Akrim Posted March 16, 2018 Share Posted March 16, 2018 Rapier Las Destroyers can be devastating but its a single finesse shot, can be supplemented by a command reroll but sometimes it will fail hard. Fantastic range though. LasPreds i like for the volume of shots. Im a bigger fan of the Vindicator Laser Destroyer, it has the best of both worlds. Lower range however. Link to comment Share on other sites More sharing options...
HeresyBeliever Posted March 16, 2018 Author Share Posted March 16, 2018 Rapier Las Destroyers can be devastating but its a single finesse shot, can be supplemented by a command reroll but sometimes it will fail hard. Fantastic range though. LasPreds i like for the volume of shots. Im a bigger fan of the Vindicator Laser Destroyer, it has the best of both worlds. Lower range however. Yes it was the Vindicators I was referring to. Shorter range only get the 4 shots if it doesn't move. But is T8 Link to comment Share on other sites More sharing options...
OPTIMVSCHRISTVS Posted March 16, 2018 Share Posted March 16, 2018 I've had great results with the laser destroyer. Both have their pros and cons- Pred has longer range, Vindicator is a bit harder to kill (T8)/easier to get into cover (lower profile), Vindicator is more reliably killy but the Pred has a higher damage potential (2 shots of flat 6 or 4 shots of flat 3 damage vs 4 shots of D6 damage). Link to comment Share on other sites More sharing options...
HeresyBeliever Posted March 16, 2018 Author Share Posted March 16, 2018 I've had great results with the laser destroyer. Both have their pros and cons- Pred has longer range, Vindicator is a bit harder to kill (T8)/easier to get into cover (lower profile), Vindicator is more reliably killy but the Pred has a higher damage potential (2 shots of flat 6 or 4 shots of flat 3 damage vs 4 shots of D6 damage). Exactly so which should I buy? Interesting to know its a lower profile good tip Link to comment Share on other sites More sharing options...
OPTIMVSCHRISTVS Posted March 16, 2018 Share Posted March 16, 2018 I've had great results with the laser destroyer. Both have their pros and cons- Pred has longer range, Vindicator is a bit harder to kill (T8)/easier to get into cover (lower profile), Vindicator is more reliably killy but the Pred has a higher damage potential (2 shots of flat 6 or 4 shots of flat 3 damage vs 4 shots of D6 damage). Exactly so which should I buy? Interesting to know its a lower profile good tip Dealer's choice, really. Which one do you think looks cooler? Go with that one. I happened to have a few plastic Vindicator kits laying around that I thought would make cool conversion fodder, so that made the choice for me. Link to comment Share on other sites More sharing options...
Akrim Posted March 16, 2018 Share Posted March 16, 2018 I would vote Vindicator Las personally. Very reliable tank killer as long as properly supported by infantry. If its more long range sniping you seek -> Pred Link to comment Share on other sites More sharing options...
