New to gk
Hugoboss8901
How is everyone getting the 2++ on the Grand master dread knight?
 Casting sanctuary first and then using the "heed the prognosticars" stratagem
How's that supposed to work? You use the Stratagem at the start of your turn so either the 2++ lasts only for your movement phase (sanctuary cast last turn) or you can't cast sanctuary due already having a 3++.
The other way around actually. You have to use the stratagem at the beginning of your turn, then cast sanctuary in the psychic phase.
That doesn't work either tho. If you use the Stratagem it already has a 3++ so Sanctuary doesn't work (improves only up to a 3++).
Don't they use their stratagem only on stratagems that are used during phases?
Currently, it's cut off. It does state that it can't be used on 'stratagems used before the battle', but that doesn't exclude Heed. Still, the full wording may clarify. It's hella expensive to use though, and you get the CP back most of the time. Doesn't change the fact it's a strong Stratagem, not only against GK.
Hey guys,
i am the player facing Muaddib with my DA, Tyranids, Guard, Inquisition (and soon Chaos).
It is true I only won a couple of games against its GK and it doesn't count, because of weird missions.
In regular matched-ups I always lost so far. :rolleyes:
I don't play Primaris, hell no heretics !
Plasma is my main weapon, especially in 8th ed.
I have quite the luck with warhammer dices, well to be accurate, i just do lots of 5+ and 6+, pretty insane rolls sometimes...
That works in both ways... My "gift" can easiliy make sure my vehicle explode in the middle of my lines... even after a reroll !
As for skills, i have some good ones but some are not needed anymore, like estimate ranges... :whistling:
I don't have enough experience with the different army lists I play.
I am learning several factions at the same time, stratagems and game mechanics, trying many various lists for each.
I am trying to adapt my armies in 8th lists. It's hard but I am getting there.
Finally it is true Muaddib is better to what the game is right now : mobile skirmish with MEK units.
As a result, the GK match-up is too high for me and the troops i have at disposal. But I keep trying, that's the spirit.
What i like the most is too see a battle, not to win it.
But frustating to keep loosing versus the GK ratata alpha strike (Interceptors and Stormraven), heavy hitter/tanker (Draigo, gmndk) and massive redeploy for objectives (Gate).
Mainly full MEK with a lot of invulnerables + every one is psyker and i don't play yet efficient counter psy units.
Enjoy it when it lasts friend, it won't be long before the Primarch himself will rise to cross swords with your Dreadknights ! :yes:
