Stoic Raptor Posted March 18, 2018 Share Posted March 18, 2018 I've been trying to find any blog entries, tutorials or videos for this, but it gets lost in the other uses... Can anyone direct me to any resource (or offer any advice) on the best techniques to use a violet shade to enhance normal skin? I'm not talking about Genestealers or Daemonettes or Drukharii or anything. I've got the notion that properly applied, a violet shade would accentuate the muscular physique and faces of my Goliaths, to start. But I'm hesitant to do "trial and error" at this stage - I want to at least be prepared, I'm sure it will still be a little challenging at first, but I'm not looking to make my Goliaths into Aberrants (at least, no moreso aberrant than they are already). Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/ Share on other sites More sharing options...
Major_Gilbear Posted March 18, 2018 Share Posted March 18, 2018 Just thin it on your palette with a little water and matte medium, and carefully glaze it into the deepest recesses of the musculature. If you simply wash it on, it'll bee too heavy and your model will look purple. You want to use your brush to paint "into" the recesses too, because this is quite thin and you will get the darkest result where the brush leaves the model. Also, by applying it as a glaze you can build up a couple of layers until you get the result you want - it's hard to mess things up as each layer is pretty translucent and you build up the effect gradually. I normally use purple paint (GW Liche Purple/P3 Beaten Purple) instead of a wash, because it's a little more opaque and so the end result has a little more colour overall (which I prefer). Stoic Raptor 1 Back to top Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5034701 Share on other sites More sharing options...
Prot Posted March 18, 2018 Share Posted March 18, 2018 I do it all the time for shaded areas. But you have to use it almost as a glaze mixed with your base flesh tones. It’s in use in my avatar of Valois. Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5034703 Share on other sites More sharing options...
Bryan Blaire Posted March 18, 2018 Share Posted March 18, 2018 I would personally only use it in the most shaded portion of the flesh areas and I would probably thin it some. When I painted this face, I tried to get a bit of a pale blue undertone to show a more pallid tone: I ended up using thinned 2:1 Guilliman Blue glaze:flow improver and glazed the lower 2/3rds of the face. Then I painted small veins with the thinned Guilliman Blue (which got covered with thinned Pallid Wych Flesh, unfortunately) to look like veins showing through the pallid skin. I also used thinned Drakehof Nightshade to shade under the eyes. Because you are looking for a more ruddy tone for your Goliaths (I'm assuming), the Druchii Violet would be a good compliment, but because it is such a deep hue, you might want to thin it so that it isn't as harsh. Keep it to those places where you would likely see the veining under the surface on a person, such as the inner portion of the elbow below the bicep and upper forearm, under the jaw and the shaded portion of the neck, etc. :lol: Double :ph34r: 'd! Stoic Raptor 1 Back to top Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5034704 Share on other sites More sharing options...
Xenith Posted March 25, 2018 Share Posted March 25, 2018 Check my chaos plog for violet shading of a 'traditional' skin tone. I generally use it around eyes and such. PeteySödes 1 Back to top Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5040137 Share on other sites More sharing options...
Stoic Raptor Posted March 25, 2018 Author Share Posted March 25, 2018 Can you provide a link please? I click on the image in the sig and all I get is a thread with a lot of Photobucket lockouts. Prot 1 Back to top Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5040380 Share on other sites More sharing options...
Prot Posted March 27, 2018 Share Posted March 27, 2018 My personal blog in my sig actually has an article on how I used it for faces recently. It's so easy to do, and you can get really nice tonal quality out of the 'glazing' techniques without a ton of effort/time. If you're like me building armies at a time.... I think it's something that might help you. Stoic Raptor and Charlo 2 Back to top Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5041451 Share on other sites More sharing options...
Stoic Raptor Posted March 27, 2018 Author Share Posted March 27, 2018 Thanks, I'll give it a look. Nice blog you've got there by the way - mind if I add it to the blogroll on The Sage Brush? Prot 1 Back to top Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5041465 Share on other sites More sharing options...
Prot Posted March 27, 2018 Share Posted March 27, 2018 Thank you. Any bit helps...hopefully the examples there aren’t too crude. (I’m in my purple phase right now. ) Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5041515 Share on other sites More sharing options...
apologist Posted March 27, 2018 Share Posted March 27, 2018 (edited) On 3/18/2018 at 2:57 PM, Knight of Lupus said: Can anyone direct me to any resource (or offer any advice) on the best techniques to use a violet shade to enhance normal skin? [...] I've got the notion that properly applied, a violet shade would accentuate the muscular physique and faces of my Goliaths, to start. But I'm hesitant to do "trial and error" at this stage - I want to at least be prepared, I'm sure it will still be a little challenging at first, but I'm not looking to make my Goliaths into Aberrants (at least, no moreso aberrant than they are already). Probably a bit late to add here, but I think the single best bit of advice I can offer is to touch in the purple selectively – a little like a 'pin wash', where the colour is carefully encouraged to sit in a certain place, rather than left to settle naturally. Doing it this way increases the contrast between the shaded areas and the remaining skin; contrast both in terms of tone (dark/light) and hue (purple/yellow). I did a step-by-step on painting a face that demonstrates some of this http://here, and that makes extensive use of purple. I've got some further explanation and examples here on painting pale skin with warm yellow and cool purple glazes for different effects: Reveal hidden contents Warm Cool Major_Gilbear's advice on building the effect up gradually is particularly valuable. Not only can you see the effect buildup until you get the result you want, but it's harder to 'overdo' things if you're working in subtle layers. I painted Unfortunus Veck's face using multiple glazes of purple, red and blue around the eyes: Edited March 27, 2018 by Apologist StraightSilver and Stoic Raptor 2 Back to top Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5041661 Share on other sites More sharing options...
StraightSilver Posted March 27, 2018 Share Posted March 27, 2018 Not a great pic but I use very thinned Druchii Violet (thinned with Lahmian Medium into a glaze) on flesh but as has been said I apply it sparingly in deepest recesses such as under eyes. I use a combination of Druchii Violet glazes and Baal Red/Carroburg Crimson. The purple I apply to deepest recesses and the red to areas i want to create warmth, such as noses, brows, between fingers.It's best to apply really thin and build up as you can add to it, it's harder to take away if you overdo it if that makes sense? Stoic Raptor 1 Back to top Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5041717 Share on other sites More sharing options...
Stoic Raptor Posted March 27, 2018 Author Share Posted March 27, 2018 Thanks, these are all great recommendations and I'm really learning a lot from you all! Please keep the suggestions coming. StraightSilver, that face looks amazing and I really appreciate the advice about applying red to warm certain areas as well. Gradual buildup is definitely an idea I can grasp - I've only done glazing a few times but it is cool to see how it develops. StraightSilver 1 Back to top Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5042313 Share on other sites More sharing options...
Ahistorian Posted March 28, 2018 Share Posted March 28, 2018 I use Druchii under Seraphim/Reikland personally StraightSilver 1 Back to top Link to comment https://bolterandchainsword.com/topic/345356-using-druchii-violet-to-shade-normal-skin/#findComment-5042633 Share on other sites More sharing options...
