Indefragable Posted April 16, 2018 Share Posted April 16, 2018 I second the notion of just chopping off bolt pistols from the hands and gluing a bolter in its place. Even for someone as unrefined as myself it comes out far more effective than you'd think and after even a coat of primer it looks like it came out of the box that way. As for loadout... I would say 98% of the time you'll want jump packs: they just give way too much utility, whether on the board, using Forlorn Fury (that extra 12"+D6" movement before the game starts instead of 6" + D6") or being able to use Descent of Angels. There are certainly ways to use them without Jump Packs, but you gotta be sure you have a concrete plan that is more reliable and efficient then jump packs. Weaponry = that old saw of "depends on the rest of your list." I generally like 2-3 Power Fists and then 1-3 Power swords in a unit of 15, but it comes down to points of course. I like being able to threaten anything with fists, but they are not my go-to unit for taking out big scary things. If I run both Sanguinary Guard AND Death Company (in theory it works, but only tried it once) then DC will be nothing but bolters and chainswords since they then fill the role of dedicated horde-sweeper. Thunder hammers can work (YMMV of course), but were I to run them, I would do 5x TH DC dudes in a Stormraven. Otherwise I like bolters so you can "John Woo" it by shooting target A and charging target B. Link to comment https://bolterandchainsword.com/topic/345602-death-co-loadout/page/2/#findComment-5056594 Share on other sites More sharing options...
toaae Posted April 16, 2018 Share Posted April 16, 2018 I use some with just bolters across their chest and some with pistols hacked off and replaced with bolters. I don't worry about not being WYSIWYG, because you can't NOT give them a second weapon, so even if they don't show it, the Bolter ones have their default CCW. Link to comment https://bolterandchainsword.com/topic/345602-death-co-loadout/page/2/#findComment-5056899 Share on other sites More sharing options...
Bremon Posted April 16, 2018 Share Posted April 16, 2018 I used the cut method for bolters swapped onto pistol arms; right arms are cut at the wrist and swapped, left I cut the bolt pistol off in front of the trigger and above the hand, and swapped the corresponding bolter piece in. I used some high quality flush cutters intended for plastic to do this. Turned out fantastic. Link to comment https://bolterandchainsword.com/topic/345602-death-co-loadout/page/2/#findComment-5057092 Share on other sites More sharing options...
