Nova_chron Posted March 29, 2018 Share Posted March 29, 2018 Hey fellow brothers and cousins of the blood. As the title says I'm trying to get myself back into gear so to speak I'm wanting to build a flesh tearers army.(will flip between chapter BA or FT based on do I want Seth in the list) I've got a mishmash of minis including ten intercessors, all the characters from DV, primaris librarian, and then a motley crew of tactical marines, assault marines, a librarian dread, storm raven, and an assortment of tanks including a siccaran I'm looking for some ideas of a strong core to build out from. What have you guys found to be best as a core force that you can almost use like a Lego base to add other groups onto I tend to play in the 1850-2500 points value range. Link to comment https://bolterandchainsword.com/topic/345701-help-me-get-the-gears-turning-again/ Share on other sites More sharing options...
Jolemai Posted March 29, 2018 Share Posted March 29, 2018 Do you have heavy weapons for Tactical? Having a battalion is ideal for Command Points so having two supporting Tactical (in the absence of Scouts) and the Intercessors along with two characters will start you off fine. Link to comment https://bolterandchainsword.com/topic/345701-help-me-get-the-gears-turning-again/#findComment-5043517 Share on other sites More sharing options...
Nova_chron Posted March 29, 2018 Author Share Posted March 29, 2018 I have all heavy options available except grav and I think I can build more. What have you found works best to add to that initial block I'm kinda trying to go with a redemption of the FT theme. So less death company and more combined arms lists keep me engaged in the games more Link to comment https://bolterandchainsword.com/topic/345701-help-me-get-the-gears-turning-again/#findComment-5043520 Share on other sites More sharing options...
