birdbath Posted April 1, 2018 Share Posted April 1, 2018 I have got around a 2k list of PM and various terminators along with a few tanks. My question is, how close towards the end of the HH that the death guard became what they looked like today in 40k? Also, when did Mort become a Daemon Prince? Thanks, Matt Link to comment https://bolterandchainsword.com/topic/345804-my-40k-death-guard-in-30k-fluff-question/ Share on other sites More sharing options...
SkimaskMohawk Posted April 1, 2018 Share Posted April 1, 2018 The Legion got super corrupted en route to Terra, but Mortarion only turned into a Daemon Prince after iirc with the whole plague planet thing. Theres a couple of tricky parts to using a 40k DG army in 30k. One ,the scale is off. This might not seem like the biggest of issues, but in a game where only the bodies count for LoS instead of everything, all your dudes being extra tall and bulky are a bit of a negative. It also means Mortarion is way too big and any blightlords you use would have bases that are too big (since all Legion terminators are on 40mm). The other issue is loadout. Unless you have a very large collection, its usually a bit harder to make 30k squads that aren't just bad. We generally have a bunch of special weapons, so you could make Tactical support squads with plasma or whatever, but anything like blight launchers would need to be counts asd. The melee weapons could be used as power weapons in vet squads, but melee vets really suck. You can basically make the following with the 8th ed range: Captain Typhon-Typhus Praetor in Cataphractii-Lord of Contagion Legion Herald-Noxious Blighbringer Librarian-Plague Caster Deathshroud Legion Dreadnought-Helbrute Legion Terminators-Blightlords Legion Apothecary- Plague Surgeon Veterans-Plague marines Tactical Marines-Plague marines Tactical Support Squad-Plague marines Legion Predator Squad Legion Land Raider Squad Legion Artillery Squad- Plagueburst Crawler The Blightspawn and Putrifier don't really have an immediate analogue, the tallyman you'd need to give a weapon to, but could be a chaplain. So you would be able to play some 30k if people wave the bases on all the characters and blightlords, but the list would be pretty bad. Link to comment https://bolterandchainsword.com/topic/345804-my-40k-death-guard-in-30k-fluff-question/#findComment-5045503 Share on other sites More sharing options...
Kilofix Posted April 1, 2018 Share Posted April 1, 2018 I think it’s fine if you have enough Plague Marines with Bolters. 1 LoC as Praetor 3 x 10 Plague Marines as Marines with Bolters 3 Surgeon, Biologus, Blightspawn as Apothecaries for the above squads Then group your specials into Special Weapon Squads Use your Blight Haulers as Mortars (cause they are small sized) Use your Crawlers as Vindicators Use your Dreads as Dreads Link to comment https://bolterandchainsword.com/topic/345804-my-40k-death-guard-in-30k-fluff-question/#findComment-5045596 Share on other sites More sharing options...
SkimaskMohawk Posted April 1, 2018 Share Posted April 1, 2018 I think it’s fine if you have enough Plague Marines with Bolters. 1 LoC as Praetor 3 x 10 Plague Marines as Marines with Bolters 3 Surgeon, Biologus, Blightspawn as Apothecaries for the above squads Then group your specials into Special Weapon Squads Use your Blight Haulers as Mortars (cause they are small sized) Use your Crawlers as Vindicators Use your Dreads as Dreads Sooo... Haulers are bigger than rapiers by a good bit. And in addition to looking nothing like a quad launcher you'd need a couple of guys with pistols to go with them, since the crew-artillery interaction is pretty important for artillery. Crawlers are also bigger than vindis. More importantly, it's gun wouldn't be able to shoot because of how line of sight works in 30k. Link to comment https://bolterandchainsword.com/topic/345804-my-40k-death-guard-in-30k-fluff-question/#findComment-5045751 Share on other sites More sharing options...
