Space Marine capes?
What sort of capes are you after?
There's one in the Space Marine Commander kit, several in the newer Terminator kits (including a wolf pelt), and one in the Deathwatch Veterans kits. You can often buy just these bits on ebay, or via various bits stores, which is usually a lot cheaper than buying the whole box. Edit: many of the Age Of Sigmar fantasy kits have great cloaks, capes, and pelts too.
Alternatively, various third-party companies make compatible capes in a variety of styles. You might try Spellcrow, Kromlech, MaxMini, Puppetswar, Anvil Industries, and see if they make anything you like the look of.
As a further alternative, you could try making your own. Putty rolled out and cut to shape is pretty popular, but so is using thick foil (like the stuff you get from tomato purée tubes for example). Tissue paper soaked with glue also works, and there's a good tutorial here by our very own member BCK.
