Underside of GW 150mm x 100mm rectangular base
It's quite a simple question really, if you have this base in your collection can you tell me what the underside is like or share a photograph?
Some of their bases have slot notches or round extrusions for drilling out and placing feet pins, and this would mean if you cut the base in two, it would still support itself fairly effectively. If the underside of the base is completely flat then it will lose some of its structural rigidity once cut, which would be a problem as I want to make a custom base out of several of these.
Thanks for any assistance.
