Storm Bolters
Has anyone found a decent source for non-TDA storm bolters? I generally find the older official GW ones to be scaled poorly for PA. I done some research but haven't found any that struck y fancy. About the closest I've come were the "Rapfire-TB2D" from shapeways. Im looking to complete some wolf guard with storm bolters so i need ~10-15
Has anyone found any they liked?
https://bolterandchainsword.com/topic/345984-storm-bolters/
I think you mean the Sternguard, not the Vanguard?
Either way, the only other source I can think of would be old 2nd edition models - the old Terminators are not too far off the newer plastic power armour models in size, and the old 2E Space Hulk plastic Terminators go for a song on ebay.
Beyond that, you have the Grey Knight power armour ones... Although I really don't like the ammo feeds on those (they add more clunkiness to an already bulky-looking weapon). :confused:
https://bolterandchainsword.com/topic/345984-storm-bolters/#findComment-5049410
I actually made two models with the wrist mounted ones from the GK kit! I thought they would mesh well with Logan Grimnars look since (i think) he was the first with that model. I didnt like it it though, maybe im too picky. I'm making my WG with the mk. III armor primarily and maybe its just an issue with that.
Seems like the issue is probably just with me. In previous editions or with chaos, Combi-bolters (twin) acted the same as SB. Would there be an issue using these as counts as SB?
https://www.shapeways.com/product/L7T6GJ7CS/10x-rapfire-tb2d?optionId=60193385
https://bolterandchainsword.com/topic/345984-storm-bolters/#findComment-5049415
https://www.forgeworld.co.uk/en-DE/Alpha-Legion-Head-Hunter-Kill-Team-Upgrade-Set
Are you after something aloong these lines?
Otherwise I quite like using the cataphractii combi bolters or the tartaros ones are not too bad, but a tad big. Think the cata combi's are a wee bit more compact.
https://www.forgeworld.co.uk/en-DE/Cataphractii-Power-Axe-Set
https://www.forgeworld.co.uk/en-DE/Legion-Tartaros-Terminator-Power-Axe-Set
https://bolterandchainsword.com/topic/345984-storm-bolters/#findComment-5049431
Lol too rich for my blood for just bolters :biggrin.:
   Have you thought of making your own? If you have a few bolt pistols from various kits (the ones not in holsters) laying about, you can glue two pistols together (shaving the plastic down where they will join), and fill the gaps with green stuff, and you get a decent looking storm bolter. Made one up for one of my Blood Angel sarges, and it looks pretty good.
https://bolterandchainsword.com/topic/345984-storm-bolters/#findComment-5049733
I’ve used the regular bolters form the sternguard set (as they have funky ammo boxes and look more ornate) then just cut the barrel off, lowered it and added a barrel from a spare bolter above it. Gives it the “over/under” look that I call the “Headhunter pattern storm bolter”
https://bolterandchainsword.com/topic/345984-storm-bolters/#findComment-5050176
