Warbringer Posted April 6, 2018 Share Posted April 6, 2018 Hey Guys Here is a copy of my blog post I just posted here <https://krakendoomcool.wordpress.com/2018/04/06/vulkan-hestan-re-modelled/ So I have been trying to add to my Salamander Force as you will have seen with the Building a better Bray'arth Ashmantle. I started collecting my bits and man I used some bits to get it right. I used the following bits to the best of my memory Head - GW's Vulkan He'stanLegs - Devastator squad,Torso - Just a standard torsoRight Arm - Banner arm from Command SquadLeft Arm - GW's Vulkan He'stan As always with this type of conversion its a pain getting the pose and you'll see I've adjusted it ever so slightly throughout, I used the grey knight spear to give me a feel for sizing. I built the spear by using the original model and cutting it to get the post I wanted as you can see I've managed to get it to the same size overall as the grey knight one which I'm chuffed with. This is the press mould I made of the cloak and all the other major details which I then managed to recreate with green stuff. Also Vulkan now standing on the 32mm base as you'll see I've added plasticard onto the bottom to the feet and rock. If I'm working with the smaller models and trying to get them to stand taller I cheat and and this to the feet. This is also a great tip (in my opinion) for getting feed out of the ground when you do your bases afterwards so your models look like they're walking on top of the basing material rather than in it!. With everything curing I put Vulkan together and I've got to say I'm really happy with the overall result, he stands as close to the Gravis Armour Primaris Marines that come in the starter box set. I'm looking forward to getting painting and seeing what I can do. I'm hoping to get a airbrush in my new hobby garage (I'm in the process of moving and renovating a house!) and see if I can get some really nice transitions on the paint. Really enjoyed building Vulkan I decided to quickly put some bits together and build him an honour guard, this also gives a good comparison on the size he stands at. They're armed with power axes and one has a master crafted bolter and the second is carrying a gladius that was given to him on campaign by an Ultramarine Sergeant. Link to comment Share on other sites More sharing options...
