Inquisitor Conversion Ideas?
Imho, above anything you want character in the model. Inquisitors are highly varied and unique individuals, so there's likely almost no way to do it wrong unless the pieces just don't fit together. I'm sure there are some Inquisitors who at a glance look much like your standard Arbites officer, Guard Commissar, or Ministorum Priest, while others are going to be clad in archaic Xenos armor with exotic archaeotech, wearing golden power armour with bound daemon weapons covered in seals of binding, or shriveled husks with blinded eyes who interact with the world solely thru their psychic abilities. Basically, get some parts, go nuts, and have fun making up a neat backstory.
I'm actually considering this from a gameplay angle. Since I'm using regular Specialist Inquisitors (as a generalist option) as my inspiration, I need them to look correct. I don't want guys in hulking power armor, as their save won't reflect it.
I was thinking I'd try to greenstuff a tabbard and a cloak and hood onto a mostly scion model. I also thought I'd try to GS a hammer together.
The old Warhammer witch hunter is a pretty decent choice as a base, and favored by many. IG commissars can work well, too. Scions... probably not *as* much. They look too uniform for a really unique look.Though some scion bits can obviously work - weapons, heads, that kind of stuff. Really, Id just browse the webstore for some neat stuff. :)
Do you need to stay GW/FW? There's lots of 3rd party stuff out there, particularly female inquisitors (or models that can be used as such)
No, but I have a box of unbuilt scions that I thought I'd try to use.
I play Imperial Guard, and I play Cadians, so my Scions are old metal Kasrkin. I have little use for the newer scions, despite having a bunch of them.
I have space wolves bits that I can use to source thunder hammers. I want to avoid power armor bits though, since average inquisitors don't get that. I was also going to try green stuff to make robes and tabbards and hoods. The heads were going to be masked scion heads.
I'm kinda planning to repaint my Scions as an inquisitorial detachment so that they might actually see use on the tabletop.
Well, this is an Inquisitor I threw together recently:
It's mostly a Tempestor from the Scions kit, but a space Marine head (which is a little large but not bad) and a pistol from the fantasy empire general kit, which I'm using to represent a needle pistol, but really you could call it any pistol, maybe even a Stormbolter since it has two barrels. Also did some cutting to fit a Powersword onto his hand instead of the puny knife. Throw on a servoskull I had lying around (I think from the Cadian Command Squad kit) and you have an Inquisitor.
