antique_nova Posted April 22, 2018 Share Posted April 22, 2018 Hi all, I was wandering if it's even possible to use GWS plastic glue to fix modelling sand to the bases? I ask, because I forgot to buy some super glue, but I will. However, if the plastic glue is enough, then I'll just stick with it. Link to comment https://bolterandchainsword.com/topic/346495-plastic-glue-for-basing/ Share on other sites More sharing options...
Major_Gilbear Posted April 22, 2018 Share Posted April 22, 2018 Unfortunately not - the plastic glue is more a solvent rather than an adhesive, and to works by essentially melting to plastic surfaces together. For gluing sand onto bases, you can use a good quality PVA glue (recommended) or cheap superglue (less recommended). Link to comment https://bolterandchainsword.com/topic/346495-plastic-glue-for-basing/#findComment-5062587 Share on other sites More sharing options...
Kinstryfe Posted April 22, 2018 Share Posted April 22, 2018 I highly recommend pva glue (good old white glue) rather than superglue. It's a lot less messy, gives you more control, and I find it generally easier to work with on bases than superglue is. Link to comment https://bolterandchainsword.com/topic/346495-plastic-glue-for-basing/#findComment-5062621 Share on other sites More sharing options...
antique_nova Posted April 22, 2018 Author Share Posted April 22, 2018 Ok. Cheers! Link to comment https://bolterandchainsword.com/topic/346495-plastic-glue-for-basing/#findComment-5062825 Share on other sites More sharing options...
