Rhino multimeltas discontiued?
Imren
Kromlech also has an alternative version.  Although I own the LC/TLPG turret from them, I can assure you their style is very applicable.
And easier to get IMHO :ph34r.:
They look pretty cool, more like a razorback turret with searchlight. perhaps gameplaywise they might give a slight disadvantage of a couple of inches if you measure from the weapons nozzle, for a multimelta that wants to enjoy the melta-rule, two inches is a lot out of twelve. Thanks!
A bit pricier, but you might consider getting the Land Raider Crusader sprue on its own from GW.
As well as the pintle Mulitmelta, you get a twin linked assault cannon turret that's a perfect match for a Razorback, and other parts for conversions/base decorations too.
If you get to make use of the sprue on at least two different vehicles, then the £12.50 cost isn't actually so bad when you compare it to what you would spend on FW or third-party bits otherwise. Plus, you know, it's plastic! ;)
If you get to make use of the sprue on at least two different vehicles, then the £12.50 cost isn't actually so bad when you compare it to what you would spend on FW or third-party bits otherwise. Plus, you know, it's plastic! :wink:
Wow, that sprue looks like a conversionists wet dream, one could make a damcloes command rhino with the smallish sat dish, and that assault cannon is seems perfect for razorbacks. Thanks alot major Gilbear.
