Imperial Guard Combat Engineers?
Hello,
A super secret project I've been working on has brought me to ask a question of you guys- does the imperial guard have combat engineers. By this I mean combat ready personnel with skills and aptitudes in the construction of fortifications, bridges, whatever might be needed to be put up (or taken down) quickly on the battlefield. Would these personnel fall under the command of a regiment, or the command of the Munitorum? Would they carry any specialist gear? And would they have any special markings to denote them as combat engineers?
Thanks in advance
https://bolterandchainsword.com/topic/346596-imperial-guard-combat-engineers/
Yes the Guard make extensive use of sappers. Because of the diverse range of regiments, you're pretty much good to go on any sort of symbols. However they would likely make use of things like Trojan support vehicles, Atlas recovery tanks, Dozer blades on everything and for some reason I have a strong association between combat engineers and flame weapons.
Add back packs to them and use heads with visors (scout heads with night vision goggles work nicely too). The old fantasy dwarf kits had lots of wrenches and other tools you can add to them. Make them look like they are prepared for any engineering emergency. If you have the hand for it, you could paint some kind of engineer symbol of your own devising.
For PDF I use Cadians in blue fatigues as my Royal army and catachan models in grey fatigues as my grubby mining guilders (combat engineers). I modeled a trio of man-portable mining laser teams for them too.
