allegedlynerdy Posted April 26, 2018 Share Posted April 26, 2018 Hello! I'm just getting into 30k, and would like to run Imperial Militia (loyalist, of course). My local group meets at a GW store, so that means I need GW models, discounting out my original plan to use anvil industries. Does anyone have any suggestions for building something up? In 40k I use steel legion, and considered doing something like that, but the limited modability of metal models deterred me to an extent. Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/ Share on other sites More sharing options...
Qkhitai Posted April 26, 2018 Share Posted April 26, 2018 Imperial Militia are pretty much only limited by your imagination and hobbying abilities. With the amount of new human models we've received in the past few years - from Necromunda, to Genestealer Cults, to Skitarii, to Kairic Acolytes and Militarum Tempestus - the possibilities for kitbashing militia have never been better! It's impossible to say which combinations will be best, so it's probably best to have a think about it and play around with some ideas yourself. The old Empire State Troops with Skitarii weapons and some head swaps is an idea I was thinking about at one point though. If you just want straight up stand in models with no conversion work, Catachans double as Calth Irregulars/Phyrian Auxillaries; Cadians as Malcador's Chosen/Syrins/Calth Regulars (especially the old metal models); and Vostroyans as Gene-Five Two Chiliad/Urslaviks (arguably). Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5066001 Share on other sites More sharing options...
Arion Posted April 27, 2018 Share Posted April 27, 2018 I've seen some great militia conversions using Warhammer Fantasy Imperial soldiers (... what's Age of Skubmar?) and wh40k lasguns. Anvil Industry has also plenty of parts and minis to use as militiamen. Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5066131 Share on other sites More sharing options...
walter h Posted April 27, 2018 Share Posted April 27, 2018 You could use the old Empire, free company box as well as the archers box. The ganger boxes do also seem to hold some opportunity for conversions. The ,G.W. ,that you go to might not have a problem as long as the relevant amount of the build meaning at least 90% of the model is ,G.W. . Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5066138 Share on other sites More sharing options...
Corswain Posted April 27, 2018 Share Posted April 27, 2018 Yeah, pretty much whatever you want. For me, I just picture 40K Guard. In my head it’s a reflection of the Imperium’s decline that the standard issue of 40K is the same as what a militia would cobble together in 30K. Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5066164 Share on other sites More sharing options...
Trokair Posted April 27, 2018 Share Posted April 27, 2018 What Provenances are you planning on using? For example if you have Survivors of the Dark Age then the Skitarii or the Van Sar Gang could be a great starting point. Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5066172 Share on other sites More sharing options...
Harrowmaster Posted April 27, 2018 Share Posted April 27, 2018 You could even use tau or eldar models if you felt like it. Regardless of what you do, photos would be appreciated Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5066235 Share on other sites More sharing options...
Leman Russ SW Posted April 27, 2018 Share Posted April 27, 2018 Beatsmen are also another good option if you want to run a CC army, you can also use the minotaurs as ogryns. Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5066729 Share on other sites More sharing options...
Ragnarr Posted April 28, 2018 Share Posted April 28, 2018 For my Space Wolves Serves 30k (Provenances: feral warriors, survivors of dark age): - force commander - inquisitor Coteaz model - converted - discipline masters cadre - scions - platoon command cadre - cadian command squad - infantry squad - cadian infantry 2x - rifle squad - infantry squad - marauders - cc squad - grenadiers 1 - hybrids - grenadiers 2 - orloc gang - recon squad - escher / van sar gang - medicae - cadians / scions medics Now I am thinkin about conversion based on skitarii. Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5067198 Share on other sites More sharing options...
Supe robot gangster #1 Posted May 1, 2018 Share Posted May 1, 2018 For my two militia regiments ive just gone for Krieg models for one, and Cadians with vic mini pith helmet heads, all with imperial eagles removed Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5069230 Share on other sites More sharing options...
Harrowmaster Posted May 1, 2018 Share Posted May 1, 2018 I made a discipline master using the storm trooper kit (built like the commander) and added a head from Anvil Industry. My force commander is based of Coteaz with a head swap (Anvil again) and a marine power axe in place of the hammer. Unfortunately the photos are too large to upload to the B&C Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5069828 Share on other sites More sharing options...
SickSix Posted May 1, 2018 Share Posted May 1, 2018 DreamForge Eisenkern if you want a sleek looking and high tech force. Link to comment https://bolterandchainsword.com/topic/346632-imperial-militia-model-recommendations/#findComment-5069962 Share on other sites More sharing options...
