C'tan Base size
Baron Sebas
Hi,
So i am converting some C'tan and the necron line is pretty inconsistent regarding base sizes (some HQ 25mm, some 40mm). Same goes for the C'tan, the transcendent C'tan is 60mm and the nightbringer & deceiver metal & resin ones differ between eachother. Do you overlords think i should put all the C'tan on 60mm? Or should i put the deceiver & nightbringer on 40mm?
(this question comes with tournament play in mind)
https://bolterandchainsword.com/topic/346669-ctan-base-size/
