SW1 Posted May 2, 2018 Share Posted May 2, 2018 Looking to do a few contemptor dreads for the ETL and have them count as Ven Dreads. Just wondering if there's any FW variants we can access in 40k I should consider? I'd really like to do a twin assault cannon version but there's no way of doing it using the options available using the index entries. Link to comment https://bolterandchainsword.com/topic/346836-question-about-contemptor-dreads/ Share on other sites More sharing options...
Quixus Posted May 2, 2018 Share Posted May 2, 2018 Any reason why you would not run them as Contemptor dreads? In case you are wondering whether Space Wolves can take Contemptors I refer you to the Imperial Armour Index FAQ p. 2. It explicitly states that Space wolves can take all units with the <CHAPTER> keyword. Link to comment https://bolterandchainsword.com/topic/346836-question-about-contemptor-dreads/#findComment-5070402 Share on other sites More sharing options...
SW1 Posted May 2, 2018 Author Share Posted May 2, 2018 I've only got the index book so unsure of other books options. If there's a contemptor with a pair of kheres assault cannons can someone confirm what it should be vowed as and the points I'd pledge? Not after the rules. ;) Link to comment https://bolterandchainsword.com/topic/346836-question-about-contemptor-dreads/#findComment-5070434 Share on other sites More sharing options...
Quixus Posted May 2, 2018 Share Posted May 2, 2018 There are actually two. The Mortis Contemptor and the Relic Contemptor. Both can have two Kheres Assault Cannons + other options. I'm not sure whether it is OK to post points if you do not have the book. You can easily look it up on battlescribe though. Link to comment https://bolterandchainsword.com/topic/346836-question-about-contemptor-dreads/#findComment-5070448 Share on other sites More sharing options...
Grotsmasha Posted May 2, 2018 Share Posted May 2, 2018 There are actually two. The Mortis Contemptor and the Relic Contemptor. Both can have two Kheres Assault Cannons + other options. I'm not sure whether it is OK to post points if you do not have the book. You can easily look it up on battlescribe though. For the purposes of ETL you can post/PM the TOTAL points value without itemising the points for each upgrade. Link to comment https://bolterandchainsword.com/topic/346836-question-about-contemptor-dreads/#findComment-5070452 Share on other sites More sharing options...
Quixus Posted May 2, 2018 Share Posted May 2, 2018 Relic Contemptor with 2 Kheres Assault Cannons 160 pts. Contemptor Mortis with 2 Kheres Assault Cannons 154 pts. Both can take a Cyclone Missile Launcher for ten meltabombs. Link to comment https://bolterandchainsword.com/topic/346836-question-about-contemptor-dreads/#findComment-5070484 Share on other sites More sharing options...
