dbecer01 Posted May 3, 2018 Share Posted May 3, 2018 Hi, I have 10 ratlings that I'm almost done painting. I've never drilled out barrles before, because my guardsmen's barrels are really thin anyway. The Ratling rifle barrels look thick enough for me to drill. However, I'm not sure if it's a good idea since they are metal, so I don't want to make a mess, or ruin the minis. Also, I've never done this, and not sure how it would look. Anyone who can offer up some advice? Link to comment https://bolterandchainsword.com/topic/346859-drilling-metal-mini-barrels/ Share on other sites More sharing options...
apologist Posted May 3, 2018 Share Posted May 3, 2018 Metal barrels can be drilled in just the same way as plastic ones; using the same tools – a pin vice – and techniques. If you feel a little uncertain, I suggest you use the point of a craft knife to mark the centre of the barrel. This will give a mark for you to drill, and will also help guide the drill bit. Work slowly; there's no rush. Link to comment https://bolterandchainsword.com/topic/346859-drilling-metal-mini-barrels/#findComment-5071131 Share on other sites More sharing options...
Major_Gilbear Posted May 3, 2018 Share Posted May 3, 2018 Yes, the technique for drilling weapons barrels is always the same regardless of material. I posted chapter-and-verse on how to do it here if you need further direction on how to go about this. :) Link to comment https://bolterandchainsword.com/topic/346859-drilling-metal-mini-barrels/#findComment-5071163 Share on other sites More sharing options...
Marshal Reinhard Posted May 3, 2018 Share Posted May 3, 2018 You just have to drill harder :P Link to comment https://bolterandchainsword.com/topic/346859-drilling-metal-mini-barrels/#findComment-5071261 Share on other sites More sharing options...
CommodusXIII Posted May 3, 2018 Share Posted May 3, 2018 I've drilled out the lasgun barrels of my old Valhallan metal minatures. I'd recommend going very slowly and not applying too much pressure. Bits that small are not very strong, and I've impaled my hand more than once when I've snapped them. Link to comment https://bolterandchainsword.com/topic/346859-drilling-metal-mini-barrels/#findComment-5071400 Share on other sites More sharing options...
dbecer01 Posted May 3, 2018 Author Share Posted May 3, 2018 Thanks, I’ve never drill out barrels at all. I’ll check out the guide. I guess I shouldn’t really have to drill more than a quarter of an inch anyway. Link to comment https://bolterandchainsword.com/topic/346859-drilling-metal-mini-barrels/#findComment-5071727 Share on other sites More sharing options...
CommodusXIII Posted May 3, 2018 Share Posted May 3, 2018 Not even that much. Drill enough to get a visible dimple/depression, and a black wash will do the rest. Link to comment https://bolterandchainsword.com/topic/346859-drilling-metal-mini-barrels/#findComment-5071732 Share on other sites More sharing options...
Golf33 Posted May 24, 2018 Share Posted May 24, 2018 Definitely don't press too hard! The drill bit can snap, then the half that's mounted in the pin vise will feel really unpleasant as it spears into your fingertip. Link to comment https://bolterandchainsword.com/topic/346859-drilling-metal-mini-barrels/#findComment-5089743 Share on other sites More sharing options...
Subtle Discord Posted May 24, 2018 Share Posted May 24, 2018 Also, in future, it's easier to drill weapon barrels before the paint job when there's no chance of tearing or peeling the paint and you don't need to go back and repaint the hole. Link to comment https://bolterandchainsword.com/topic/346859-drilling-metal-mini-barrels/#findComment-5089777 Share on other sites More sharing options...
