Battle Brothers/Battle Forged
McElMcNinja
With the new FAQ, if I take a Chaos Lord and a Chaos Sorcerer from the CSM Codex both with the Mark of Nurgle and put them in a detachment with 3 units of Nurglings from the Daemon Codex, is this a legal Battle Forged Battalion that I would gain access to stratagems from both codex and be able to use in organized events?
https://bolterandchainsword.com/topic/346921-battle-brothersbattle-forged/
Yes. Make sure that the (Mark of Chaos) or Nurgle in your case is in the Key Words section. The Daemon Prince has it setup in a different area so you cannot use a Daemon Prince from the CSM codex and run Daemons as the troops without breaking the Battle Brothers rule.
It’s indeed battleforged, but does not meat the requirements to access the stratsas per each codex. For example CSM detachment needs to be all CSM, same for CD if I’m not mistaken :/
This is correct, you would need a detachment of chaos demons, AND, death guard to be able to access each specific factions stratagems.
