Solution: Death Guard Green Base
Guest
I am trying to use Death Guard Green (base not air) thru a .33 needle (Badger Krome). however it seems either extremely thick or thin. I am hoping someone with more experience with airbrushes and this color can help me get a good ratio of paint / thinner and at what psi.
Solution: So I discussed with some other painter who are by far more experienced. DG Green doesn't cover as well as other base paints I have used before (ex: mechanicus standard grey. I was told to use the DG Green rattle can as Prot suggested, but as that is not an option, to use white primer OR Vallejo parched grass. The Vallejo parched grass was the better option as a single coat or two of DG Green would cover it, the parched grass is slighlty darker. So I wasn't going crazy as I thought about this paint. I just hope that someone learns from this.
https://bolterandchainsword.com/topic/347059-solution-death-guard-green-base/
