NiceGuyAdi Posted May 14, 2018 Share Posted May 14, 2018 I'm trying to get the canopy on my storm Talon tinted. First go was with Vallejo clear and a total failure (doesn't settle evenly). I'm looking at trying this again with Tamiya Clears. They have a number of colours, but I want to create a smoked glass look, which they don't make. But they do make a pigmentless clear. I wondered if I could add some drops of nuln oil to this to get the effect? Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/ Share on other sites More sharing options...
Razblood Posted May 14, 2018 Share Posted May 14, 2018 There is a smoke clear in the tamiya range X-19, which is used for that purpose. Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5081139 Share on other sites More sharing options...
Arkhanist Posted May 14, 2018 Share Posted May 14, 2018 I use tamika clear red mixed with a little brown or purple wash to get nice clotted blood effects, but it wouldn't work as a clear tint anymore as mixing standard acrylic almost curdles the tamiya. The tamiya clears are alcohol based, so I'm not sure of it's the water or polymer that has that effect on it. Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5081348 Share on other sites More sharing options...
PeteySödes Posted May 14, 2018 Share Posted May 14, 2018 As Razblood says, the smoke is what you want, it works great. Ive used that as well as the yellow for tinting canopies. Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5081359 Share on other sites More sharing options...
NiceGuyAdi Posted May 14, 2018 Author Share Posted May 14, 2018 Smashing, thanks a lot, all. I thought I'd heard of Tamiya Smoke before, but couldn't find it today when I was looking. This has saved me a load of trouble. Thanks again! Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5081463 Share on other sites More sharing options...
Evil Eye Posted May 16, 2018 Share Posted May 16, 2018 Tamiya Smoke is definitely worth it. Tamiya do a colourless Clear paint that you could tint with ink though. I tried doing so with purple ink from a craft shop and it worked a charm. Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5083032 Share on other sites More sharing options...
NiceGuyAdi Posted May 18, 2018 Author Share Posted May 18, 2018 Squigsquasher I'll definitely bear that in mind. For now my clear green and smoke have arrived. So next question. Can I just mask off the areas of the canopy to paint the main areas in smoke, and the HUD in green? Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5085587 Share on other sites More sharing options...
NiceGuyAdi Posted July 4, 2018 Author Share Posted July 4, 2018 Hope this isn’t considered threadomancy, but I’ve tried putting the Tamiya Clears down on the canopy and can’t manage to get an even coat. Is there a trick to this? It keeps drying blotchy. It feels like it’s too thick so doesn’t find its level as it dries. Can I thin it with a little alcohol? Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5117316 Share on other sites More sharing options...
PeteySödes Posted July 4, 2018 Share Posted July 4, 2018 I slather it on and let it drop down hanging it from the sprue. Works pretty well for me. Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5117370 Share on other sites More sharing options...
Bung Posted July 5, 2018 Share Posted July 5, 2018 Use the Tamiya Thinner X20a and an airbrush for even coats. Doing it with a psintbrush wont give you good results with that colors. But i find Createx Candy2o colors superior for that kind of work. Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5117853 Share on other sites More sharing options...
NiceGuyAdi Posted July 5, 2018 Author Share Posted July 5, 2018 an airbrush isn’t an option for me right now, unfortunately, though it could be in six months so I’ll check that out. The createx as well. For now I’ve given the ‘slop it in and let it hang’ approach and it seems to be going better. I’d been putting not enough on and standing it the wrong way up, before. Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5117926 Share on other sites More sharing options...
Grimoire Posted July 5, 2018 Share Posted July 5, 2018 Late to the party with this. I've always used Future Floor Polish tinted appropriately. Works great in 1/48 and 1/72 scale. Now I always sprayed it with an airbrush. But I do know quite a few that can brush apply it. It levels very well. Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5118049 Share on other sites More sharing options...
Trixie Posted July 5, 2018 Share Posted July 5, 2018 When using tamiya clears you should be rocking a 50/50 mix with x-20a thinner and for best results you really need the airbrush. Sorry I can't provide anything else Edit - Badger Minitaire 'Ghost Tints' have a clear paint range that can be thinned with water or regular non alco thinner. They are great in an airbrush but have no xp using them with a regular brush. Link to comment https://bolterandchainsword.com/topic/347254-tinting-tamiya-clears/#findComment-5118284 Share on other sites More sharing options...
