Iron_Within Posted May 16, 2018 Share Posted May 16, 2018 So in 2000 point game where you know you can't be facing issue tiaamii such as Imperial Guard is it best to take one heldrake or two? How to make a very good for shutting down things for the first time charge however with one they always die come the second turn would a second heldrake be beneficial? Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/ Share on other sites More sharing options...
Aothaine Posted May 16, 2018 Share Posted May 16, 2018 Always at least 2. If you have room take three in a flyer wing. Redundancy is key. Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5083665 Share on other sites More sharing options...
Panzer Posted May 17, 2018 Share Posted May 17, 2018 All of them! :D Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5083800 Share on other sites More sharing options...
Iron_Within Posted May 17, 2018 Author Share Posted May 17, 2018 All of them! So two barebones Sorcerers, 3 10 man units of Cultists and 9 Helldrakes got it! Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5083881 Share on other sites More sharing options...
Iron_Within Posted May 17, 2018 Author Share Posted May 17, 2018 More seriously the list I was thinning of running is this: Daemon prince: talons mark of Nurgle 8 zerkers x3 + power weapons 3 rhinos X3 cultists 6 Havoks x4 autocannon 6 Havoks x4 missile launchers 6 Havoks x3 lascannons 1 missile launcher 2 helldrakes w. Baleflamers Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5084096 Share on other sites More sharing options...
GreaterChickenofTzeentch Posted May 17, 2018 Share Posted May 17, 2018 More seriously the list I was thinning of running is this: Daemon prince: talons mark of Nurgle 8 zerkers x3 + power weapons 3 rhinos X3 cultists 6 Havoks x4 autocannon 6 Havoks x4 missile launchers 6 Havoks x3 lascannons 1 missile launcher 2 helldrakes w. Baleflamers Not bad. You can kill enemy armor, pop open transports, and otherwise cause confusion, and the Prince and Zerkers combine with the Drakes for good threat overload. Going to mark the Drakes with Nurgle to take advantage of synergy with the Prince's psychic powers? Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5084398 Share on other sites More sharing options...
GreaterChickenofTzeentch Posted May 17, 2018 Share Posted May 17, 2018 Always at least 2. If you have room take three in a flyer wing. Redundancy is key. You can drop to 1 if you have a large number of other large threats that require attention (Maulerfiends, Defilers, Brutes, Rhinos full of Berzerkers, etc.) I personally run 1 Baleflamer Drake with my Iron Warriors sometimes, flanked by 2 Hell Blades for cost reduction. My Thousand Sons can run 2 plus a Storm Eagle. My Night Lords have 1, but it's accompanied by a shedload of Raptors, Warp Talons, Chaos Spawn, Contemptor Dreadnoughts, and other fast stuff. Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5084400 Share on other sites More sharing options...
Aothaine Posted May 17, 2018 Share Posted May 17, 2018 You can drop to 1 if you have a large number of other large threats that require attention (Maulerfiends, Defilers, Brutes, Rhinos full of Berzerkers, etc.) This is also true. But you have to be sure the other threats are big enough to pull fire off the Heldrake. A Leviathan of two might do the trick. Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5084413 Share on other sites More sharing options...
Iron_Within Posted May 17, 2018 Author Share Posted May 17, 2018 Going to mark the Drakes with Nurgle to take advantage of synergy with the Prince's psychic powers? Yes, gonna stick Nurgle on the Rhinos too, first turn the intention is to rush the zerkers in rhino's forward, pop smoke and drop one with Miasma of pestilence - normally I have a 40 man cultist squad with miasma on so everyone is at -1 the first turn. Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5084421 Share on other sites More sharing options...
Aothaine Posted May 17, 2018 Share Posted May 17, 2018 Yes, gonna stick Nurgle on the Rhinos too, first turn the intention is to rush the zerkers in rhino's forward, pop smoke and drop one with Miasma of pestilence - normally I have a 40 man cultist squad with miasma on so everyone is at -1 the first turn. Usually better to cast Miasma of Pestilence on your Daemon Prince to make sure he has a better chance at surviving until he hits melee. It is good for him even after that though as well. Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5084450 Share on other sites More sharing options...
Panzer Posted May 18, 2018 Share Posted May 18, 2018 The Daemon Prince can just hide behind other units tho since it's a character with less than 10 wounds ... like behind a Rhino with Miasma for example. ;) Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5084790 Share on other sites More sharing options...
Iron_Within Posted May 18, 2018 Author Share Posted May 18, 2018 Yup that's the idea, in previous games I've had 40 cultists with Miasma placed on them, which can be nasty when you've got an assault horde with -1 to hit on them (Iron Warriors), must be nice with the -2 to hit with Alpha Legion :P Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5084835 Share on other sites More sharing options...
Iron Father Ferrum Posted May 18, 2018 Share Posted May 18, 2018 I do that with my Dreadnoughts since they're where most of my antitank comes from, but putting Miasma on a Drake isn't a terrible idea. Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5085058 Share on other sites More sharing options...
Aothaine Posted May 18, 2018 Share Posted May 18, 2018 The Daemon Prince can just hide behind other units tho since it's a character with less than 10 wounds ... like behind a Rhino with Miasma for example. Ahh good point. Link to comment https://bolterandchainsword.com/topic/347342-helldrakes-1-or-2/#findComment-5085199 Share on other sites More sharing options...
