Fahlnor Posted May 20, 2018 Share Posted May 20, 2018 Discuss! Link to comment https://bolterandchainsword.com/topic/347461-land-raider-vs-stormraven/ Share on other sites More sharing options...
Xerxus Posted May 20, 2018 Share Posted May 20, 2018 Stormraven wins out massively due to being a fast flyer with the supersonic rule that also brings more dakka at the same cost. Land Raider doesn't even have superior durability in many cases. Link to comment https://bolterandchainsword.com/topic/347461-land-raider-vs-stormraven/#findComment-5086452 Share on other sites More sharing options...
Xenith Posted May 20, 2018 Share Posted May 20, 2018 In terms of what? Land raider Proteus with heavy armour is pretty tough and tasty. Link to comment https://bolterandchainsword.com/topic/347461-land-raider-vs-stormraven/#findComment-5086471 Share on other sites More sharing options...
Fahlnor Posted May 20, 2018 Author Share Posted May 20, 2018 Which one is most durable? Does a Land Raider’s T8, two additional wounds and the 2+ save win out against the Stormraven’s -1 To Hit modifier and significant mobility advantage? How useful have you found the fact that a Stormraven can’t be charged by a Knight or a unit of Terminators? Which can bring the most firepower? The Land Raider can bring four lascannon shots, a heavy bolter, a multimelta, storm bolter and a hunter killer missile. The Stormraven has more options and can add hurricane bolters to any loadout, in addition to bringing the stormstrike missiles. Which brings the most useful transport capacity? Is the 16-man Crusader overshadowed by the Stormraven bringing a Dreadnought? If you’re not bringing a Dreadnought, does the value swing in favour of the Land Raider? Is it more useful to have a slightly larger transport capacity and increased durability versus the ability to put a smaller squad anywhere you like on the board? Any other things you want to add? Is one of them just cooler than the other? How do they compare for points? Do you see one of them more often than the other? Would either of them run particularly well in multiples or in a particularly themed army? Link to comment https://bolterandchainsword.com/topic/347461-land-raider-vs-stormraven/#findComment-5086486 Share on other sites More sharing options...
sebs_evo7 Posted May 20, 2018 Share Posted May 20, 2018 Land raider because it’s cooler Link to comment https://bolterandchainsword.com/topic/347461-land-raider-vs-stormraven/#findComment-5086495 Share on other sites More sharing options...
Spyros Posted May 20, 2018 Share Posted May 20, 2018 A LR can "hide" behind a suitably large building, or itself block LOS to other units. At the same time it needs bigger roads to move. A SR has increased maneuverability but a lot more enemy models can draw LOS to it, and the -1 to hit is nothing compared to 7th edition's 6+ to hit (unless you are anti-aircraft). Link to comment https://bolterandchainsword.com/topic/347461-land-raider-vs-stormraven/#findComment-5086510 Share on other sites More sharing options...
Karhedron Posted May 20, 2018 Share Posted May 20, 2018 For me the Storm Raven's ability to FLY is the winning factor. If you are using either vehicle to transport infantry then you will need to get close to the enemy which in turn risks you getting charged. Not only can Raven's not be charged by non-flying units but even if they do get charged, they can move off and fire without penalty on the next turn. The Land Raider is too expensive to risk sacrificing its firepower if it gets charged, even if the opponent fails to do any damage, the loss of shooting may well hurt your battle plans. Link to comment https://bolterandchainsword.com/topic/347461-land-raider-vs-stormraven/#findComment-5086782 Share on other sites More sharing options...
Brother Crimson Posted May 20, 2018 Share Posted May 20, 2018 If you get out FW land raider options I’d would field a Storm Raven over land raider most of the time. It’s been said above The thing you can do with land raiders is to block line of sight. You could try to hide infantry behind it so they can’t be shot in addition to the transported one. Unfortunately for the poor land raider, I’d rather have 3 razorbacks as transport, it’s just more wound or firepower. The stormraven in the other has a lot more to offer: maneuvering, fly, versatility in loadout, dreadnought transport, etc. I really hope LR get is points adjusted. Link to comment https://bolterandchainsword.com/topic/347461-land-raider-vs-stormraven/#findComment-5086785 Share on other sites More sharing options...
