Claws and Effect Posted May 21, 2018 Share Posted May 21, 2018 Ok, I just noticed a possible really cool combination, and I'm asking to verify that everything interacts the way I think it does. 1) Does a character embarked in a transport count as being on the battlefield for the purpose of effects that require him to be to work? I'm not talking about auras, I know those don't work in transports. Specifically I'm considering putting a Deathwatch Warlord in a Damocles Command Rhino with the Warlord Trait that gives you back command points on a 5+. All it says is that he has to be on the battlefield. Will that trait function if he is in a transport that is on the table, or does he have to be on foot? 2) I'm considering combining a Deathwatch detachment with a Blood Angels detachment. If I give a Blood Angels character the relic that does the same thing as the above mentioned warlord trait, do I get to roll 2 dice when I use a strategem? And if they both succeed, do I get 2 command points back? Link to comment https://bolterandchainsword.com/topic/347491-2-part-question/ Share on other sites More sharing options...
Mr. Shine Posted May 21, 2018 Share Posted May 21, 2018 1) No. The rules for embarking tell us that embarking units are removed from the battlefield. We can also infer this from the following FAQ answer on resolving destroyed transports and disembarking formerly-embarked units: "Note that if the transport does explode, units being transported are not affected as they are not yet on the battlefield." 2) Don't see any reason you can't use both and get two command points back, provided again they're both on the battlefield. Link to comment https://bolterandchainsword.com/topic/347491-2-part-question/#findComment-5087041 Share on other sites More sharing options...
Claws and Effect Posted May 21, 2018 Author Share Posted May 21, 2018 Cool, thanks. I kinda thought the Command Rhino thing might not work. Saves me some money at least, since I haven't bought one yet. Neat that I could potentially end up with more command points than I started with if I use 1 CP Strategems and succeed on both rolls. Definitely helps the pure Marine list difficulty with generating command points. I'm working out a potential tournament list already :) Link to comment https://bolterandchainsword.com/topic/347491-2-part-question/#findComment-5087049 Share on other sites More sharing options...
I_Heart_69 Posted May 24, 2018 Share Posted May 24, 2018 I might not be remembering this correctly, but doesn’t your warlord need to be from a particular faction to unlock that faction’s relics? Link to comment https://bolterandchainsword.com/topic/347491-2-part-question/#findComment-5090154 Share on other sites More sharing options...
Dr_Ruminahui Posted May 24, 2018 Share Posted May 24, 2018 For the free relic, yes. For the 1 CP & 3 CP Stratagems, you only need to have access to those stratagems and a character or character from the appropriate codex to put the relic(s) on. Link to comment https://bolterandchainsword.com/topic/347491-2-part-question/#findComment-5090162 Share on other sites More sharing options...
I_Heart_69 Posted May 24, 2018 Share Posted May 24, 2018 Ah, thanks for that clarification. Anyways, I like the idea of a CP factory. Link to comment https://bolterandchainsword.com/topic/347491-2-part-question/#findComment-5090242 Share on other sites More sharing options...
UnkyHamHam Posted May 25, 2018 Share Posted May 25, 2018 It works for Ultramarines as their warlord trait only has the stipulation that they are alive, not the additional one of also being on the battlefield like other similar warlord traits. Link to comment https://bolterandchainsword.com/topic/347491-2-part-question/#findComment-5090886 Share on other sites More sharing options...
