Teleportarium Stratagem
It says the strategem can only be used once and that for each CP spent one unit goes into the teleportarium, so it sounds like they all count as a single deployment.
That's an interesting interpretation because it would run contrary to every other type of "hold this unit off during deployment" type rule.  I'm not sure which way it is but my feeling is that each unit counts as 1 drop is the RAI, but RAW I could argue for either.
I agree with Vel in that RAW, it can be taken both ways (but to me, it leans towards a single deployment because the strategem is one use only), but RAI it probably should be separate deployments.
It does work against us though. Since it's during deployment and not before, if you place your WL with Hidden Knowledge trait first, then if they're separate you get up to 3 rolls to recover CP. If a single use, you only get one roll.
