World Eater Tartaros Terminator conversion help.
Nerds with boxing gloves look wrong ;)
Seriously though that kitbash looks great. If you maybe enlarge the collar a bit and put a MkIV/Tartaros helmet in the body piece you would have very nice Tartaros Terminators.
Minor criticism, I think the upper  part of the shoulder pads should be in contact with the torso.
Nerds with boxing gloves look wrong :wink:
It's just 'tacked together for the pic, the pads were attached to the torso, but would sink for the pic
I don't think they would work on tartaros arms, but consider these pads and/or these insignia.
I have the forge world world eaters shoulders. Could you elaborate as to why they wouldn't work with the torso and shoulder pads from the forge.
Could I not simply shave the arm down to fit?
You'll actually need to go the other way, as the Tartaros arms have no .... "attachment" point for shoulder pads like traditional terminator arms. You'll need to build up the arms or fill the pads with greenstuff etc., but it is doable, just more involved than going the other way :tu:
Cheers,
Jono
Cheers,
Jono
Seems simple enough. Just make a relief with green stuff of the regular Terminator inner shoulderpad than greenstuff them onto the model using a mold. Add the forge world shoulders and done
Just to be 100% clear I'm using the GW version not the Forge world version for the Terminators.. the World eater conversion kit is the only thing From forge world.
https://www.games-workshop.com/resources/catalog/product/920x950/99120101171_TartarosTerminators01.jpg
