solarisqc Posted June 14, 2018 Share Posted June 14, 2018 Simple question here, if a model using heroic intervention come into contact with a knight with a fist, can the knight target the model with Deathgrip even if he have not declare a charge against it? The stratagem have specific targeting rules (single model unit less than 1'' away) but the stratagem also say make 1 additional attack so do you need a valid target for the attack our you only use the targeting rules writen in the stratagem? Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/ Share on other sites More sharing options...
solarisqc Posted June 14, 2018 Author Share Posted June 14, 2018 I like the idea of a small hero doing heroic intervention to save his comrade and be taken in a deathgrip by the knight before he can do anything. Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5105550 Share on other sites More sharing options...
PeteySödes Posted June 14, 2018 Share Posted June 14, 2018 Based on RAW "after the models fights" and "enemy unit that consists of 1 model" i'd say yea they could snipe an intervening model out. Seems pretty clear thoughI it may be FAQ bait but atm I think it'd be allowable. Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5105551 Share on other sites More sharing options...
Stray Posted June 14, 2018 Share Posted June 14, 2018 I would say yes, absolutely. RAW, there are two elements which constitute requirements to use Death Grip: - The Knight must have fought. - The Knight must choose an enemy unit within 1", that consists of a single model, to be the target of Death Grip. There's nothing to say that the Knight must have charged, only that he must have fought (so if the Knight has been charged, performed an HI etc, these should all be valid scenarios as the Knight can fight - whether first or second). It also states nowhere that the Knight must use Death Grip on the unit he had been fighting. So a character that has HI'd into combat, would be at risk if in range. Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5105553 Share on other sites More sharing options...
solarisqc Posted June 14, 2018 Author Share Posted June 14, 2018 Thanks for the fast answer, i also think the stratagem can target someone doing HI but i want to highlight it. I hpoe it's included in the FAQ just to make it clear. Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5105557 Share on other sites More sharing options...
Stray Posted June 14, 2018 Share Posted June 14, 2018 Thanks for the fast answer, i also think the stratagem can target someone doing HI but i want to highlight it. I hpoe it's included in the FAQ just to make it clear. It certainly could be clearer :) I've added your question to the boards FAQ for others to look at. Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5105559 Share on other sites More sharing options...
Lysere Posted June 14, 2018 Share Posted June 14, 2018 The main issue regarding Deathgrip is does it skip the assault rule of not being able to target something you didn't charge? I can see it going either way honestly but you can always just declare the charge anyway and be good since GW hasn't taken a firm stance on what counts as having "charged." Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5105678 Share on other sites More sharing options...
facmanpob Posted June 15, 2018 Share Posted June 15, 2018 A different question on the same topic: The Death Grip stratagem says "Use this Stratagem immediately after fighting...". Does that mean after you have finished the Fight phase for the Knight (i.e. steps 1-6 including consolidate movement), or just after you have finished step 5 (Resolve close combat attacks)? Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5105971 Share on other sites More sharing options...
Stray Posted June 15, 2018 Share Posted June 15, 2018 A different question on the same topic: The Death Grip stratagem says "Use this Stratagem immediately after fighting...". Does that mean after you have finished the Fight phase for the Knight (i.e. steps 1-6 including consolidate movement), or just after you have finished step 5 (Resolve close combat attacks)? Honestly? I don't think it's possible to tell from the wording in this instance. For me, I suspect the intent is to use the Strat straight after you resolve your last CC attack, but that's little more than a guess based on 'feel'. I'd go with whatever interpretation feels right to you, and if an opponent disagrees, roll off to see which version you go with. It's just not clear enough to rule on conclusively. Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5105974 Share on other sites More sharing options...
Khulu Posted June 15, 2018 Share Posted June 15, 2018 I don't think this is nearly so clear as people are saying. It is an attack, and nothing in the stratagem tells you to ignore standard targeting rules for attacks. Specifying a unit within 1" doesn't automatically mean any unit within 1" because the game has limitations built in already, none of which are explicitly circumvented here. With regards to consolidation I think RAW it is allowed because that happens before you conclude "fighting". I think an FAQ will likely change this, though, because after attacking makes much more sense. Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5106068 Share on other sites More sharing options...
Vel'Cona Posted June 15, 2018 Share Posted June 15, 2018 Speaking of our impeding IK FAQ, has this been submitted to GW? Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5106312 Share on other sites More sharing options...
Khulu Posted June 15, 2018 Share Posted June 15, 2018 I have, on both counts. Link to comment https://bolterandchainsword.com/topic/348184-deathgrip-question-vs-heroic-intervention/#findComment-5106371 Share on other sites More sharing options...
