ZONKEY Posted June 21, 2018 Share Posted June 21, 2018 Hi, I want to return to my death guard after their new lease of life or living impairedness, I was just pondering could I use one of the new brilliant death shroud model as Typhus as im not a great fan of the new model, are the models the similar enough in stature for me to count a Death Shroud model as Typhus? Many Thanks for any help, Zonkey Link to comment https://bolterandchainsword.com/topic/348358-using-a-death-shroud-model-as-typhus/ Share on other sites More sharing options...
Tokugawa Posted June 21, 2018 Share Posted June 21, 2018 If your opponent agree, that is OK. They both wear Cataphractii armour, but GW supplies "official" Typhus kit with a 50mm base. Never know why there is such difference. Link to comment https://bolterandchainsword.com/topic/348358-using-a-death-shroud-model-as-typhus/#findComment-5109817 Share on other sites More sharing options...
ZONKEY Posted June 21, 2018 Author Share Posted June 21, 2018 Hi, If I used a bigger base the death shroud should be ok. Link to comment https://bolterandchainsword.com/topic/348358-using-a-death-shroud-model-as-typhus/#findComment-5109831 Share on other sites More sharing options...
Jukkiz Posted June 21, 2018 Share Posted June 21, 2018 If your opponent agree, that is OK. They both wear Cataphractii armour, but GW supplies "official" Typhus kit with a 50mm base. Never know why there is such difference. It´s basically same as why normal marines got upped into 32MM bases. Becasue you get "less of them" in same close combat. Link to comment https://bolterandchainsword.com/topic/348358-using-a-death-shroud-model-as-typhus/#findComment-5109841 Share on other sites More sharing options...
Panzer Posted June 21, 2018 Share Posted June 21, 2018 The real reason is because it looks better. That's all GW cares for with such things. There're also no rules that tell you what base size to use for any of your models so technically nobody could complain if you were to use a 20mm base even as silly as that would look. :D Link to comment https://bolterandchainsword.com/topic/348358-using-a-death-shroud-model-as-typhus/#findComment-5109852 Share on other sites More sharing options...
Tokugawa Posted June 28, 2018 Share Posted June 28, 2018 The real reason is because it looks better. That's all GW cares for with such things. There're also no rules that tell you what base size to use for any of your models so technically nobody could complain if you were to use a 20mm base even as silly as that would look. :D https://whc-cdn.games-workshop.com/wp-content/uploads/2018/06/age_of_sigmar_core_rules_designers_commentary_base_sizes_en.pdf GW just released the official suggested base size list for AOS, today. I am afraid that GW will do this in 40K soon. Link to comment https://bolterandchainsword.com/topic/348358-using-a-death-shroud-model-as-typhus/#findComment-5114173 Share on other sites More sharing options...
Panzer Posted June 28, 2018 Share Posted June 28, 2018 The real reason is because it looks better. That's all GW cares for with such things. There're also no rules that tell you what base size to use for any of your models so technically nobody could complain if you were to use a 20mm base even as silly as that would look. https://whc-cdn.games-workshop.com/wp-content/uploads/2018/06/age_of_sigmar_core_rules_designers_commentary_base_sizes_en.pdf GW just released the official suggested base size list for AOS, today. I am afraid that GW will do this in 40K soon. Well I hope they do. It's silly to not have a fix base size for each unit. That being said, the AoS base sizes are only for Matched Play and only a suggestion according to the pdf. Link to comment https://bolterandchainsword.com/topic/348358-using-a-death-shroud-model-as-typhus/#findComment-5114213 Share on other sites More sharing options...
SkimaskMohawk Posted June 29, 2018 Share Posted June 29, 2018 They're also inconsistent with what comes in the box for a lot of things. Ogres are all listed on 50s even though they get shipped with 40s; Medusa is listed on a 60, but shipped with a 40 again Link to comment https://bolterandchainsword.com/topic/348358-using-a-death-shroud-model-as-typhus/#findComment-5114690 Share on other sites More sharing options...
Ishagu Posted July 5, 2018 Share Posted July 5, 2018 The bigger base size does also increase aura ranges Link to comment https://bolterandchainsword.com/topic/348358-using-a-death-shroud-model-as-typhus/#findComment-5117932 Share on other sites More sharing options...
