Home-made transfers: color decal on black field?
I am trying to use decals to add red warband/squad symbols over black and running into some difficulty I hope someone can help with.
I've got the symbols using Carlsen's awesome coat of arms from this site, printed with ink jet on both white and clear decal paper, seal decals and applied them as normal - the process worked well except the red came out way darker than I hoped.
I am pretty sure the issue is the lack of color saturation on the red from my home printer - I am curious if anyone has a work around for this. My only idea so far is to paint red under where I plan to apply the decal to bring the base color closer to the end result, but I'm a bit worried I'm going to have the same issue with the black border area of the decal.
How complex is the design?  Would it be easier to touch up the red areas with a very thin highlight of brighter red after application/sealing?
Not sure if its visible due to glare but here's an image of the symbol where I did that:
http://i.imgur.com/iCzWu6O.jpg
It's a stylized Khorne symbol. Honestly the hope with the decals was to avoid a lot of free hand painting. I can manage large symbols alright (tank-size) but I'm dubious I can manage the infantry sized ones, at least not without a lot of clean up work.
I wrote up my method for getting transfers over black in my WiP:
http://www.bolterandchainsword.com/topic/317665-lost-in-the-eye-niceguyadis-raven-guard/page-2?do=findComment&comment=4503717
Basically you use the decal as a stencil and tidy up once it’s on. Hope that helps.
Perfect guide - exactly what I was looking for! Thanks NiceGuyAdi!
