Guest Triszin Posted June 21, 2018 Share Posted June 21, 2018 Looking for some storage for my dreadnaughts, tau suits, and tanks, any advice? Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/ Share on other sites More sharing options...
Magos Takatus Posted June 21, 2018 Share Posted June 21, 2018 This chap has a pretty good war of storing most tyoes of models. I watched this video less than an hour ago funnily enough. I suppose with tanks you could fit magnets into the tracks. Skimmer tanks might be tricky unless you make your own bases instead of flying stands. Tool boxes are also fairly useful for storing larger models. I am going to find this problem getting more difficult when I start adding a second or possibly third Dunecrawler to my Skitarii. Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5110195 Share on other sites More sharing options...
Aothaine Posted June 21, 2018 Share Posted June 21, 2018 http://www.battlefoam.com/ That is the site I usually goto for my storage needs. They can even do custom designs as well. Edit: https://us.battlefoam.com/warhammer-40k/ There is a link to their 40k custom foam trays. ^_^ Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5110202 Share on other sites More sharing options...
Progenitor Posted June 22, 2018 Share Posted June 22, 2018 I've got nothing but good things to say about the Feldherr stuff. https://www.feldherr.net/ Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5110413 Share on other sites More sharing options...
facmanpob Posted June 22, 2018 Share Posted June 22, 2018 KR Multicase for the win! Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5110496 Share on other sites More sharing options...
Tannarak Posted June 24, 2018 Share Posted June 24, 2018 If you do go the Battlefoam route, they usually have a 4th of July sale. around 25% off depending on what it is. Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5111638 Share on other sites More sharing options...
Exilyth Posted July 16, 2018 Share Posted July 16, 2018 Back in the day I used deep freeze plastic bags for transporting squads, kept closed with a plastic clip - result: some broken off weapons and chipped paint from models tumbling around inside the bags. What can I say, I was young and didn't know better. I'm using feldherr XL hard cases for army transport nowadays, not the cheapest but easy to use and durable. And with raster foam inlays/trays, no need for made-to-order customized trays. But don't just listen to me, look at all foam tray makers and pick the one that suits your needs best. Before getting a foam tray case, I went to the local DIY store and calculated the cost for a toolbox with inlays made from insulation foam and arrived at similar figures, but with more assembly required. Your mileage may vary depending on region and DIY store and intended size of box and inlays. For storage. I've kept the cardboard boxes of many gw kits I bought - using some left over foam from raster/pluck foam inlays as padding and stacking multiple boxes in a large hard plastic container, they make for a relatively cheap but safe and durable storage solution. Sticky labels make it easy to know what's inside each box without having to look inside. That magnets + bacon trays method is smart though - I'll have to try that out some time. Looks like one could transport more models in the same space with that method. Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5125225 Share on other sites More sharing options...
Ishagu Posted July 17, 2018 Share Posted July 17, 2018 I use KR multicase to store anything from a guardsman to an Imperial Knight. Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5125442 Share on other sites More sharing options...
Blindhamster Posted July 17, 2018 Share Posted July 17, 2018 I too use kr multicase. My largest models are the astreus and a thunderhawk Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5125798 Share on other sites More sharing options...
NiceGuyAdi Posted July 18, 2018 Share Posted July 18, 2018 I went with a similar system to the roasting trays. Weston A5 storage boxes with a magnetic sheet glued into the bottom. They’re neat and compact. For infantry models you can get a lot into a small space, but it’s no good for very tall models (holding things aloft) or vehicles. Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5126088 Share on other sites More sharing options...
Lephisto Posted July 18, 2018 Share Posted July 18, 2018 KR Multicase is Superior by far. Will fit anything and has foam trays customized to your miniatures shapes. Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5126116 Share on other sites More sharing options...
Guest Triszin Posted July 18, 2018 Share Posted July 18, 2018 I ended grabbing some Feldherr foam pick and pluck foam storage units and some water proof storage containers from my local store. Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5126242 Share on other sites More sharing options...
thewarriorhunter Posted July 19, 2018 Share Posted July 19, 2018 I'm late to the party but I'll throw another vote in for KR. Their website is difficult to navigate but if you take a little time you'll figure it out. Their CS is also great. I used excel to block out what trays I needed and shot it off to them for confirmation and they replied instantly and helped me out. If you can try going in on a group buy so you can get free shipping (if you're in the states). Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5126618 Share on other sites More sharing options...
RandomMarine Posted July 24, 2018 Share Posted July 24, 2018 KR is my go to storage option Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5130009 Share on other sites More sharing options...
Karhedron Posted July 30, 2018 Share Posted July 30, 2018 Another KR fan here. I have also used Feldherr for X-wing minis and the quality of the products are similar. It is probably just a case of finding which is more cost effective for the particular models you wish to store. Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5133551 Share on other sites More sharing options...
Burni Posted August 1, 2018 Share Posted August 1, 2018 I’ve got a few KR card cases which I use for storage but am probably going to start gaming properly for the first time so will need to transport stuff to my FLGS. What do people think of the KR outer cases? It seems like I’d need the one that takes 3 card boxes as I have a few Armigers and Dunecrawlers. Is the ‘open case then one another case’ thing annoying? I do like the look of the Gifts for Geeks cases and the way it opens but the tray range isn’t as good. Anyone tried those? Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5135302 Share on other sites More sharing options...
Ishagu Posted August 1, 2018 Share Posted August 1, 2018 I really like the KR Kaiser transport bags for the cases. I have one that transports 4 card cases, and one for two cases. Really easy to carry, and waterproof. I wouldn't put it on my back however, even though you can. I recommend the Kaiser bag for two card boxes as it's the most convenient size for carrying an army of 2 - 3k and easily fit under tables, etc. Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5135366 Share on other sites More sharing options...
thewarriorhunter Posted August 1, 2018 Share Posted August 1, 2018 I've got a KR bag as well, the one for two cases. Bought it second hand so it's got a tournament patch I've never heard of but it's solid. It would be very uncomfortable on your back but it is possible. If you're just carrying it from your storage to vehicle to game and back I think it's great. It has enough extra pockets that you can easily fit rule books, dice, etc.in it. Link to comment https://bolterandchainsword.com/topic/348378-storage-cases-for-larger-models-many/#findComment-5135594 Share on other sites More sharing options...
