Defensive auras/abilities
Hey guys,
Looking at putting together a list with some Fire Raptors. I know they got hit hard with the nerf bat, but I almost prefer playing with a unit that isn’t just completely OP, and I love the models.
Anyway, I’ve been looking for the options for defensive abilities to see what might be the best way to take them.
So far all I’ve been able to think of/find are:
Deredeo Dread 5++
Tigurius -1 to hit for one
DA Darkshroud -1 to hit aura
Skyshield 5++
I’m sure there’s more out there, what can you think of? Any imperial ally that could still work on the raptors would be great. Thanks guys!
https://bolterandchainsword.com/topic/348545-defensive-aurasabilities/
You could also use Ravenguard tactics so you’d be at -2 to hit at more than 12 inches away. You could then use your librarian to cast might of heroes on a raptor which brings it to T8 so even if they manage to hit it, it’ll be harder to wound.
Obviously you could also do this with ultramarines and cast the power and use Tigurius’ buff and the end result would be exactly the same but doing it via ravenguard would give you a bit more flexibility in that you wouldn’t have to be within 6 inches of Tiggy. It’s also cheaper because you would only need a basic librarian instead of Tigurius and your whole army would be benefiting from the Raven Guard tactic :)
Obviously you could also do this with ultramarines and cast the power and use Tigurius’ buff and the end result would be exactly the same but doing it via ravenguard would give you a bit more flexibility in that you wouldn’t have to be within 6 inches of Tiggy. It’s also cheaper because you would only need a basic librarian instead of Tigurius and your whole army would be benefiting from the Raven Guard tactic :smile.:
fire raptors get chaptor tactics?
Nop, Marines aren't cool enough.
Ah crud, I forget marines are the only ones not to get it on vehicles! Ignore everything I said :)
