JBugman Posted July 9, 2018 Share Posted July 9, 2018 I play with a small group of friends using power levels and only recently ventured out into the world and played at stores with points. The single Battalion I use is suitable for power levels but not robust enough for the 2000 point games being played, so I have to choose additional detachment(s). Is there any preference to a second (or third) detachment or will any do as long as it fits your play style. I suspect this may have something to do with CPs. Thanks in advance, JBugman Link to comment Share on other sites More sharing options...
MARK0SIAN Posted July 9, 2018 Share Posted July 9, 2018 At 2000 points you should be easily able to fill a brigade (depending on the models you own) so always go for that as 12cps is brilliant. The other detachments can’t really offer anything to compete with that unless you’re running Lords of War. If you don’t own enough/the right models for a brigade then just get another battalion. If where you play doesn’t allow duplicate detachments then just choose the one that suits your play style :) Link to comment Share on other sites More sharing options...
WarriorFish Posted July 9, 2018 Share Posted July 9, 2018 Indeed, as mentioned a Brigade is quite easily done should you have need of all the role choices (and that's easy too ;) ). Otherwise a Battalion to get the bulk of your army down always works well, then you can flavour as needs require :) Realistically though, the "standard" detachments are normal for Guard as whatever elements you take usually want some troopers to help escort them. The only exception as again mentioned is if you want to roll out a Lord of War, but that's another easy choice for Guard in the Supreme Command detachment usually. Link to comment Share on other sites More sharing options...
FallenSoldiers Posted July 9, 2018 Share Posted July 9, 2018 Remember LRBTs in a spearhead gain ObSec! Link to comment Share on other sites More sharing options...
JBugman Posted July 9, 2018 Author Share Posted July 9, 2018 Thanks for the suggestions! I saw the thread about fleshing out your Brigades and that helped too. Brigades it is then. Link to comment Share on other sites More sharing options...
duz_ Posted July 10, 2018 Share Posted July 10, 2018 Personally I'm not a fan of IG brigades (mainly because the toys I like are too expensive to fit into it) With CP changes dual battalion + spearhead or vanguard should have you sitting pretty especially with CP farming WL and relic if necessary. Link to comment Share on other sites More sharing options...
