Making custom honour guard
Hello everyone. I have been wanting to convert my own honour guard, since GW only sells the Ultramarine honour guard, which annoys me. Does anyone know of a really good kit bash to get realistic looking honour guard? Its so hard because I need them to really stand out.
I appreciate any help I get from you guys!
https://bolterandchainsword.com/topic/348877-making-custom-honour-guard/
If I were doing loyalists I'd be eyeballing those Invictarus Suzerain as the main body to work off. There are obviously Ultramarine icons to remove but those bodies are really well detailed and would be fitting for a body guard. You can then scavenge capes and cloaks from existing plastic kits to add some flair to stand out more. Then just arm them literally, give them fancy shoulder pads from the Sternguard or Vanguard kits for example, and some unique heads or helms and BLAM!
You guys......are awesome! Lol. Did not think of the suzerain or sanguinary guard ideas. Now that I think about it, the sanguinary guard idea doesn't require any work from me. The blood drops can easily be painted as water drops, since my custom chapter resides on an ocean planet. Thank you so much guys! I knew I would get some quality help. :)
Convert up some of your own!
Here are mine:
I'll end my shameless plug there.
Actually, I'll point out that these were built back when a tooled-out Honour Guard unit meant they had power weapon, relic blade, bolt pistol, boltgun AND auxilliary grenade launcher.
I love the Sanguinary Guard kit (I've bought at least 6 for the MkIV jump packs so have used it frequently here and there), and find that much of the fanciness will fit in anywhere. Astartes are the Angels of the Emperor so wings, jewels, sculpted armour, etc all tend to fit in pretty much anywhere as long as you paint it to match
Here are mine:
Fantastic looking honour guard, love the color scheme and mix of parts. Very well done brother!
I'd looked at using Sanguinary Guard for mine initially but I instead found the Reivers box to be good base to start with, some of the dynamic poses they offered were great and not tailored to a jumpack. I then added the Company Champion helmet and shoulder pad, some third party tabards, tilt shields, storm shields and green stuff capes to finish them off.
KnightsoftheSword 01
I did my Imperial Fists Honour Guard based on the Codex Datasheet with Power Axe and Boltguns.
Base is Sternguard mixed in with bits out of the Vanguard kit and other Space Marine Kit. Got some cloaks from Anvil Industries. I'm happy with the result. They are still unpainted but you get the idea.
