Tempestus Scions Help
Not that I'm a card player, but I just wanted to point out that you've pictured a Spade, not a Club, which would have three lobes. I'm just mentioning it to ensure you're searching using the right terminology. As mentioned it's a very common symbol and if you can't find a ready-made solution you could easily lay out a page of Spade shapes found in the icons of many fonts. If you use vector-based software to create the icons they can be resized anytime with no loss of detail or sharpness.
There's actually one on the Cadian transfer sheet from GW but it's white - you could reverse the symbol though so black background with white symbol if that helps? The spade decal fits Cadian shoulder pads no problem and there's a larger one which fits vehicles too. I should have photos of mine witht hem on so I'll try to dig them out.
Update: OK so curse of Photobucket strikes again and as my Cadians are very old now I don't have many photos but here is one of the spade decals on a Sentinel:
There is a much smaller one on the same sheet that fits shoulder pads.
