General Strike Posted July 21, 2018 Share Posted July 21, 2018 Does anyone know what the best way to do this is? I want to use the Primaris range and various chaos bits to convert my chaos army, would it be easier to use regular marine arms with primaris bodies? Link to comment https://bolterandchainsword.com/topic/349032-converting-bolt-rifles-to-boltguns-chaos-primaris-help/ Share on other sites More sharing options...
Dracos Posted July 21, 2018 Share Posted July 21, 2018 I think the only thing you'd really need to do is shave the scope off. Other than that, if your using Chaos heads, shoulder pads and assorted bitz, it should be obvious to any but the most thickheaded that what you have is a truescale Adeptus Hereticus Marine ;) Link to comment https://bolterandchainsword.com/topic/349032-converting-bolt-rifles-to-boltguns-chaos-primaris-help/#findComment-5128247 Share on other sites More sharing options...
choppyred Posted July 21, 2018 Share Posted July 21, 2018 Could get some bolt carbines from the revers set Link to comment https://bolterandchainsword.com/topic/349032-converting-bolt-rifles-to-boltguns-chaos-primaris-help/#findComment-5128256 Share on other sites More sharing options...
General Strike Posted July 22, 2018 Author Share Posted July 22, 2018 Ooooh the bolt carbines idea is perfect. I cut the foregrip off and bam, boltgun. I plan on converting the Reivers into Berserkers, so I wont need those carbines anyway! Link to comment https://bolterandchainsword.com/topic/349032-converting-bolt-rifles-to-boltguns-chaos-primaris-help/#findComment-5128337 Share on other sites More sharing options...
carnosaur93 Posted July 22, 2018 Share Posted July 22, 2018 they are pretty easy to cut down in length along the line at the front of the foregrip, its what iam doing myself, only thing is that you then need to attach a new barrel, little nubbin above it and bar below, i used some tiny peices of plastic card for this, but it should also be easy enough to use what you cut off.alternatively, you can just use normal (chaos) bolters, just cut the bolt rifle off of the right primaris hand and replace the left hand supporting it with a normal bolter-supporting one, and then you can put a normal bolter on there as usual Link to comment https://bolterandchainsword.com/topic/349032-converting-bolt-rifles-to-boltguns-chaos-primaris-help/#findComment-5128432 Share on other sites More sharing options...
General Strike Posted July 23, 2018 Author Share Posted July 23, 2018 I just took a look at the hellblasters sprue online and the guns aren't attached to the arms for them, so I might be able to position the hellblaster arms to hold various regular marine weapons. Much cleaner than cutting the hands off the intercessors. Link to comment https://bolterandchainsword.com/topic/349032-converting-bolt-rifles-to-boltguns-chaos-primaris-help/#findComment-5128925 Share on other sites More sharing options...
Ahistorian Posted July 29, 2018 Share Posted July 29, 2018 Normal marine arms work on Intercessors; using CSM arms should work, abd would help Chaos-ify them Link to comment https://bolterandchainsword.com/topic/349032-converting-bolt-rifles-to-boltguns-chaos-primaris-help/#findComment-5132852 Share on other sites More sharing options...
