Tartaros Terminators chain fist attachments
Does anyone know if the chain fist attachments from the plastic Tartaros kit will fit properly under the power fists from the regular Indomitus Terminator kits?
It looks like they slip over the power cable end, but is that the same size on both types of TDA?
The "chainfist" part fits near tartaros termies powerfist connector, near said powerfist itself where cable goes and over that. It presses agaisnt that hill type part and sits neatly against and partly over that spot. Sure you can almost make them fit straight from the box at normal termies power fists, just test fit and look where groove of the chainpart goes on the powerfist before slapping glue anywhere. You most likely need some shaving and fitting, greenstuff too to get nice, seamless fit but they indeed look pretty nice.
Another use for these chain parts can be bayonets or chain daggers if you like those.
