Bulwyf Posted August 9, 2018 Share Posted August 9, 2018 I played a game today with my Space Wolves against the shady DG player in my local meta I mentioned before. He was using two DPs which wasn't odd until he told me one of them was an Index prince. I questioned why that would matter and he told me that since it was Index prince he had access to Warptime which he was going to use on Mortarion. I didn't think that was legal but he said Battlescribe lists it as an option and he pointed to this thread: https://www.reddit.com/r/BattleScribe/comments/951f4i/death_guard_has_two_listings_for_demon_prince/ He states that he believes his Index model is a totally different model than the codex prince even though the only difference is the index model has access to warp time. I've seen him use some shady stuff in the past like casting Putrscent Vitality on Morty/DP so I'm more than skeptical about this. I can't argue with him about it being an option in Battlescribe but BS is not official. Would anyone care to inform me if what he did was legal in the rules? Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/ Share on other sites More sharing options...
BlackTriton Posted August 9, 2018 Share Posted August 9, 2018 This was the ruling of my local TO: Index datasheet are replaced by the codex one. A model my take wargear options from the index, but psychic power are not wargear. Finally, any psychic ability given to an index faction is replaced by the powers from the codex if availlable. But, in RAW your oponent did not break any rules. He did break the obvious intent of the developer that the contagion discipline replaces index options. And that is abuse to me. Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/#findComment-5141735 Share on other sites More sharing options...
Azekai Posted August 9, 2018 Share Posted August 9, 2018 I have played with Index Princes. I like death hex and warptime, sue me :PIf he does that just make sure he doesn't use any DR rolls, because DG Index Princes don't get access to it. Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/#findComment-5141743 Share on other sites More sharing options...
Prot Posted August 9, 2018 Share Posted August 9, 2018 By the letter of the rule, it is legal. When I went to the ITC GT they didn't understand how it worked and I let it be, and just took the codex DP, but it's widely understood this is leveraged quite a bit in competitive play (There's a Dark Eldar unit that has a similar shadiness to it which is also often used). I would never take it normal play. I mean a LOT of competitive players just throw in an 'Alpha Legion" detachment with Sorc for Warptime/Death hex. It's easy enough to do. Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/#findComment-5141746 Share on other sites More sharing options...
Bulwyf Posted August 9, 2018 Author Share Posted August 9, 2018 So it is legal as RAW. Great. This guy...if there is any cheese to be had he'll stuff it to the max. I don't understand why if you don't want to use a CSM patrol detachment...couldn't you just take the nurgle familiar stratagem to replace one of Morty's spells to Warptime and just use it that way? A DP without DR in a DG army is just asking for trouble. Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/#findComment-5141756 Share on other sites More sharing options...
DominikB Posted August 9, 2018 Share Posted August 9, 2018 This was the ruling of my local TO: Index datasheet are replaced by the codex one. A model my take wargear options from the index, but psychic power are not wargear. Finally, any psychic ability given to an index faction is replaced by the powers from the codex if availlable. But, in RAW your oponent did not break any rules. He did break the obvious intent of the developer that the contagion discipline replaces index options. And that is abuse to me. ITC TO rules the same way, but I think he didn’t understand the different entries point. ETC was fine Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/#findComment-5141774 Share on other sites More sharing options...
BlackTriton Posted August 9, 2018 Share Posted August 9, 2018 I agree it is legal and would not blame anyone for using all the dirty trick in a tournament. Still, its abusing the intent of a game where the rule is to be upholded by the players. It is clearly not intended for deathguard to be allowed to take a CSM DP with Deathguard keyword. But here we are where it is legal. Bulwyf, one cannot use deathguard Familiar of nurgle to get warptime since it allows you to change a power for a CONTAGION power. You need the CSM familiar strat for warptime. Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/#findComment-5141781 Share on other sites More sharing options...
Bulwyf Posted August 9, 2018 Author Share Posted August 9, 2018 I agree it is legal and would not blame anyone for using all the dirty trick in a tournament. Still, its abusing the intent of a game where the rule is to be upholded by the players. It is clearly not intended for deathguard to be allowed to take a CSM DP with Deathguard keyword. But here we are where it is legal. Bulwyf, one cannot use deathguard Familiar of nurgle to get warptime since it allows you to change a power for a CONTAGION power. You need the CSM familiar strat for warptime. Ah, thanks for that, I thought it gave options for both psker schools. Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/#findComment-5141796 Share on other sites More sharing options...
McElMcNinja Posted August 10, 2018 Share Posted August 10, 2018 The reason it's legal is because they have different names on their data sheets. One is a Daemon Prince of Nurgle (Codex Death Guard) while the other is Daemon Prince of Chaos (Index Chaos). So you could run, in this case, 6 DP's in one army. Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/#findComment-5141930 Share on other sites More sharing options...
Azekai Posted August 10, 2018 Share Posted August 10, 2018 By the same logic, palanquin sorcerers also use the heretic astartes psyker powers, if I am not mistaken. Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/#findComment-5141942 Share on other sites More sharing options...
DominikB Posted August 10, 2018 Share Posted August 10, 2018 By the same logic, palanquin sorcerers also use the heretic astartes psyker powers, if I am not mistaken. Yes, however in their case it’s obvious as they are definitely not in the codex where the DP is stretching it more Link to comment https://bolterandchainsword.com/topic/349485-are-index-demon-prince-waccess-to-warptime-legal-to-play/#findComment-5141972 Share on other sites More sharing options...
