Titanicus 3rd Party Terrain Resource Thread
Warcrade il doing something: https://blog.warcradle.com/blog/new-wargame-terrain-with-dark-assembly-8mm
And there are also buildings from 4ground on the way: https://www.facebook.com/4Groundmodels
They are also rescaling their industrial terrain.:happy.:
  • 1 month later...
I'm just looking for some ruins for my bases, anyone know of anything? I looked into the old Epic ruins and they're a mint on eBay.
I've broken up some of the newer terrain on my bases, and that goes quite a long way once you cut it into sizable chunks.
As Kilofix suggested, it might be a good idea to look at model railways scenics or smaller scale ruins - if you didn't fancy cutting stuff up. Otherwise, I'd work with Milliput or similar to create some very ruined terrain!
  • 1 month later...
New terrain kits out!
Defence Line Shielder Emplacement - £5.50
Resin casting of a concrete anti-aircraft defence line emplacement.
This model has a cast on cruciform weapons mount.
Set contains:
1 x resin defence line weapons emplacement
1 x metal shielder turret
1 x metal ammo box stack
https://vanguardminiatures.co.uk/shop/defence-line-shielder-emplacement/
Shielder Emplacement - £4.50
Resin casting of a concrete shielder emplacement.
Set contains:
1 x resin emplacement
https://vanguardminiatures.co.uk/shop/shielder-emplacement/
Defence Line Rapier Emplacement - £5.50
Resin casting of a concrete missile launcher defence line emplacement.
Set contains:
1 x resin defence line emplacement
1 x metal rapier turret
https://vanguardminiatures.co.uk/shop/defence-line-rapier-emplacement/
Rapier Emplacement - £4.50
Resin casting of a concrete rapier emplacement.
Set contains:
https://vanguardminiatures.co.uk/shop/rapier-emplacement/
Hail
I found this piece of awesome hotness: https://ttcombat.com/collections/just-in/products/leviathan-district
It looks swell, I think. Does anyone have experience with TTCombat as a retailer or the Just-In manufacturer?
Faithfully,
Master Ciaphas
They recently acquired Hawk Wargames and so own Dropzone and Dropfleet Commander. I ahven't ordered form them yet, but have found that they have been commendably honest and frank in communication about fulfilling the final aspects of the Dropfleet kickstarter. I believe they were originally solely a terrain manufacturer and form most account do pretty well with that. The thing you linked to is a recent addition which many Dropzone players suspect is a direct reaction to AT being released.
So, yes, I gather they are a good company but have limited personal experience with them.
Even more terrain kits!
Defence Line Archer Emplacement - £5.50
WASoX8Z.jpg?1
Resin casting of a concrete artillery defence line emplacement.
Set contains:
1 x metal Archer gun
1 x stack of shells
1 x double shells
1 x shell trolley
https://vanguardminiatures.co.uk/shop/defence-line-archer-emplacement/
Novan Oil Drums (Fuel Dump) - £3.50
A2MSB9R.jpg?1
Novan oil drums set consists of the following items:
3 x stacks of 9 drums
3 x stacks of 6 drums
3 x stacks of 5 drums
6 x drums in cradles
16 x single drums
6mm infantry figure for size reference only not included.
https://vanguardminiatures.co.uk/shop/novan-oil-drums-fuel-dump/
Defence Line Emplacement - £3.50
FT1Om3f.jpg?1
Resin casting of a concrete defence line emplacement.
Set contains:
https://vanguardminiatures.co.uk/shop/defence-line-emplacement/
  • 2 weeks later...
Need more bits?
Novan Logistics Boxes (Supply Dump) - £4.00
7GHRyUw.jpg?1
A set of Novan logistics/equipment boxes consisting of the following:
4 x individual boxes sprues + 4 additional loose boxes
3 x stacked boxes sprues
https://vanguardminiatures.co.uk/shop/novan-logistics-boxes-supply-dump/
  • 3 weeks later...
Need some illumination?
Wall Lights (6mm) - £2.00
Wall mountable lights set that can be glued to any flat surface on building walls or even used as ground mounted lights on runways or other landing zones.
Set contains:
30 x lights
See images for size comparison and demonstration of use, here seen on TMG plastic terrain tiles.
6mm figure shown for scale.
https://vanguardminiatures.co.uk/shop/wall-lights-6mm/
Street Lights (6mm) - £6.50
3wkuA1E.jpg?1
A set of city street lights in two variants, single and double lamps, (6mm scale).
Set contents 24 x street lights:
12 x single lights
12 x double lights
6mm figure show for scale.
https://vanguardminiatures.co.uk/shop/street-lights-6mm/
