General Strike Posted August 21, 2018 Share Posted August 21, 2018 Anyone have any advice on kitbashing soem gravis terminators. I have two ideas, one is to just use the larger legs of aggressors on regular or cataphracti TDA. The other is to replace the arms of aggressors with TDA arms. What do you think will work better, before I invest in kits. Link to comment https://bolterandchainsword.com/topic/349769-gravis-terminators/ Share on other sites More sharing options...
Cryptix Posted August 22, 2018 Share Posted August 22, 2018 To answer your question, I'd just use terminator weapons if you, like me, like the style of the agressors. However, many don't, and in that case you could probably just use agressor legs. The most difficult part would be getting the legs separate from the torso, as the hips are joined to the torso bit while the lower leg is separate. EDIT: A note for if you go for the first option: on both the easy to build sprues and the normal ones, the weapon arms are separate form the body, so that increases the ease of conversion. Link to comment https://bolterandchainsword.com/topic/349769-gravis-terminators/#findComment-5150577 Share on other sites More sharing options...
General Strike Posted August 22, 2018 Author Share Posted August 22, 2018 This is the general pca questions? The weapon arms do definitely sound easier. Link to comment https://bolterandchainsword.com/topic/349769-gravis-terminators/#findComment-5150585 Share on other sites More sharing options...
Cryptix Posted August 22, 2018 Share Posted August 22, 2018 I just got on the site and was very confused for a moment, ignore me. Link to comment https://bolterandchainsword.com/topic/349769-gravis-terminators/#findComment-5150655 Share on other sites More sharing options...
Rik Lightstar Posted August 22, 2018 Share Posted August 22, 2018 Terminator arms should work well on the Aggressors, along with their shoulder pads. Also consider trimming down the "cowl" over the Aggressor's head and using the Cataphracti heads instead. Rik Link to comment https://bolterandchainsword.com/topic/349769-gravis-terminators/#findComment-5151178 Share on other sites More sharing options...
