Brother Handro Posted August 21, 2018 Share Posted August 21, 2018 I'm sure you've all wanted to remove plastic parts or like me, made a mistake and not realised until way after drying time, a quick glance at the web shows that 'plastic glue creates a weld not a bond, it can't be undone, just cut it', etc etc. Two words; Hair dryer! I can't believe this worked, I'd glued my brand new Warlord Titan's lower legs on backwards and didn't notice until after 3 days painting and coming to final assembly. A hair dryer just heated up the glue until it went tacky, like it does in that 30 seconds or so adjustment time you have when playing around with poses, and I just popped open the upper leg and switched the lower around, easy as that! Didn't even damage the paintwork! TLDR; Try applying some heat (stay safe!) to plastic glue, it worked for me, seems odd no one else has noticed/tried before. Aarik, Shovellovin, LameBeard and 8 others 11 Back to top Link to comment https://bolterandchainsword.com/topic/349770-removing-plastic-glue/ Share on other sites More sharing options...
Pork Chop Express Posted August 22, 2018 Share Posted August 22, 2018 That’s brilliant! Brother Handro 1 Back to top Link to comment https://bolterandchainsword.com/topic/349770-removing-plastic-glue/#findComment-5150675 Share on other sites More sharing options...
Aeri Posted November 7, 2020 Share Posted November 7, 2020 I know I am 2 years late to the party, but I think I still need to share this: Try putting a model in the freezer for a few hours until the glue is frozen. The Plastic can handle this. Then boil some water and let it cool to about 80°C. Also prepare a bowl of ice water. Now take your model from the freezer and put it straight into the hot water, letting it warm up for a few seconds. (You don't want Plastik stew, so don't overdo it). Now take the model from the hot water to the ice water. The super glue should snap or weaken enought to come apart. Aarik 1 Back to top Link to comment https://bolterandchainsword.com/topic/349770-removing-plastic-glue/#findComment-5628704 Share on other sites More sharing options...
byrd9999 Posted November 7, 2020 Share Posted November 7, 2020 That's great to know, thanks. I use 100% isopropanol to dissolve glue on my models when something needs correcting. I have to be patient, and apply it with a paintbrush to the affected area, but it gradually dissolves and weakens enough to prise apart the pieces, but the plastic is unaffected. Link to comment https://bolterandchainsword.com/topic/349770-removing-plastic-glue/#findComment-5628784 Share on other sites More sharing options...
Xenith Posted November 11, 2020 Share Posted November 11, 2020 I know I am 2 years late to the party, but I think I still need to share this: Try putting a model in the freezer for a few hours until the glue is frozen. The Plastic can handle this. Then boil some water and let it cool to about 80°C. Also prepare a bowl of ice water. Now take your model from the freezer and put it straight into the hot water, letting it warm up for a few seconds. (You don't want Plastik stew, so don't overdo it). Now take the model from the hot water to the ice water. The super glue should snap or weaken enought to come apart. I highlighted the key thing there - the OP is talking about plastic glue, or poly cement, while your method works on cyanoacylate, or superglue. They bond the material in different ways, so those methods wont work on the other type of bond. Freezer makes the super glue brittle, and breakable, but this won't work on plastic glue, which melts the plastic and fuses them together. Link to comment https://bolterandchainsword.com/topic/349770-removing-plastic-glue/#findComment-5630088 Share on other sites More sharing options...
LameBeard Posted April 25, 2021 Share Posted April 25, 2021 I am sorry for Necroposting but please can I say thank you, Brother Handro. You just saved an Adeptus Titanicus Warlord from being an interesting source of spare parts. Grotsmasha 1 Back to top Link to comment https://bolterandchainsword.com/topic/349770-removing-plastic-glue/#findComment-5692042 Share on other sites More sharing options...
Maker666 Posted March 18, 2024 Share Posted March 18, 2024 Plastic glues are actually strong solvents that melt plastics and glue them together because they micromelt. You would have to use some method to temporarily alter the consistency of the plastic such as cooling it or, if not the opposite, heating it with water. The cold could make the parts brittle and cause them to split where you don't want them to. With heat, don't heat it too much either, to prevent it from deforming forever. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/349770-removing-plastic-glue/#findComment-6028919 Share on other sites More sharing options...
