Fytharin Posted August 24, 2018 Share Posted August 24, 2018 Hi folks, so just coming back and it's been a long while...I've been teased and known for not putting terrain on my bases but I'm looking to change that in masse. I know a bunch of our units had their base size changed and was hoping I could get a run down on those so I can make sure everything I own is up to date.From what I recall, pretty much all of our basic marines got upgraded to 32 mm, is that right? Right now I have the following still on 25 mm's and I'm thinking they all need to be upgraded? Just looking for confirmation before I put in the work or someone who can point me in the right direction article wise. I couldn't find any space wolf specific discussion on the topic. Long Fangs Gray Hunters Ulric Rune Priest Sky Claws Thanks for the help! EDIT: I found talk of some 32mm being upgraded to 40mm also? Is that true? Link to comment https://bolterandchainsword.com/topic/349846-32mm-base-size-change/ Share on other sites More sharing options...
Fytharin Posted August 24, 2018 Author Share Posted August 24, 2018 Of course as soon as I post, I find this:https://www.dakkadakka.com/wiki/en/Basing_Guidelines_for_Warhammer_40,000#Space_Marines Link to comment https://bolterandchainsword.com/topic/349846-32mm-base-size-change/#findComment-5153044 Share on other sites More sharing options...
PeteySödes Posted August 24, 2018 Share Posted August 24, 2018 List looks right, the 32mm werent used prior to that change so TDA is still 40mm. A buddy of mine went this route: https://www.secretweaponminiatures.com/index.php?main_page=product_info&products_id=761 Link to comment https://bolterandchainsword.com/topic/349846-32mm-base-size-change/#findComment-5153045 Share on other sites More sharing options...
Fytharin Posted August 24, 2018 Author Share Posted August 24, 2018 Nice, I think if I had bases already done up I might consider that route too. As it is...all of my bases are naked so seems like a great time to kill 2 birds with one blow. Link to comment https://bolterandchainsword.com/topic/349846-32mm-base-size-change/#findComment-5153048 Share on other sites More sharing options...
Karack Blackstone Posted August 24, 2018 Share Posted August 24, 2018 https://www.secretweaponminiatures.com/index.php?main_page=product_info&products_id=761 Link to comment https://bolterandchainsword.com/topic/349846-32mm-base-size-change/#findComment-5153049 Share on other sites More sharing options...
Wispy Posted August 24, 2018 Share Posted August 24, 2018 List looks right, the 32mm werent used prior to that change so TDA is still 40mm. A buddy of mine went this route: https://www.secretweaponminiatures.com/index.php?main_page=product_info&products_id=761 Damn i need to get those for ny Bloodclaws. There's only 4 of them right now, but I'll be buying new product to fill out the rest of the squad and i dont want the bases to be mismatched. I'm probably going to leave my Greyhunter bases as is though. Link to comment https://bolterandchainsword.com/topic/349846-32mm-base-size-change/#findComment-5153050 Share on other sites More sharing options...
Jarl of Wulfen Posted August 24, 2018 Share Posted August 24, 2018 I restarted my wolves using mk3 and mk4 armor and gave them an interior/biarding action look using http://www.secretweaponminiatures.com/index.php?main_page=product_info&cPath=79_30_61&products_id=754 and http://www.secretweaponminiatures.com/index.php?main_page=product_info&cPath=79_30_41&products_id=753 Link to comment https://bolterandchainsword.com/topic/349846-32mm-base-size-change/#findComment-5153081 Share on other sites More sharing options...
Nadir Posted August 24, 2018 Share Posted August 24, 2018 It's called base adapters. You can find those on different sites. Sometimes you need to mask the connection between the two halves with a putty, but I was manage to do that in my army (150+ figures), so you will be fine I think :) One more thing: you don't have to change the bases, but all new minis have bigger ones, and they look cooler that way- bigger. Link to comment https://bolterandchainsword.com/topic/349846-32mm-base-size-change/#findComment-5153142 Share on other sites More sharing options...
brother_b Posted August 25, 2018 Share Posted August 25, 2018 Those secret weapon adapters aren't that good, there is another adapter that has a lip it makes it easier to put on the models . I'll try and find it. Edit: http://ttadapters.com These are the adapters I used. This is the place I bough them. Link to comment https://bolterandchainsword.com/topic/349846-32mm-base-size-change/#findComment-5153303 Share on other sites More sharing options...
