Unblocking an airbrush nozzle
Hey all. I was airbrushing my Imperial Knight yesterday and once I finished for the day I took the airbrush apart and cleaned it. I soaked the parts in airbrush cleaner and then ran them through an ultrasonic cleaner. When it came to reassembling the airbrush I found the needle would no longer fit inside the nozzle. I left it to soak in airbrush cleaner overnight but by morning I still cannot see through the nozzle.
Does anyone experienced in airbrush usage know any tips beyond what I'm doing to clear whatever has got stuck in the nozzle? I'm hesitant to apply force in case I damage any of the components.
Thank you for your time.
https://bolterandchainsword.com/topic/349877-unblocking-an-airbrush-nozzle/
Some nail varnish remover uses other type of thinners than acetone, you need to check the table of contents on the label. The ones that's just acetone (also used as nail varnish remover) works good and its acetone I have experience of. Make sure its soaks for 10-15 min so that the acetone gets the chance to work through the blockage.
