Index space wolves
Wolf Lord Loki
So I noticed that the Lone Wolf and the Iron Priest on Thunderwolf didn't make it into the codex.
I'm assuming I can still use my models with the stats from the index if I wish.
I have a (IMHO) kick ass iron priest on a Thunderwolf I wish to continue using. But I suspect my twin powerfist Lone wolf is a no go....
https://bolterandchainsword.com/topic/349934-index-space-wolves/
The Iron Priest on Thunderwolf should be fine, as there is no listing in the codex that replaces or supersedes it. However, if we go by the FAQ ruling for the Tau codex, where a piece of wargear in the index is replaced by a strategem in the codex, the Lone Wolf will no longer be allowed.
Most recent options replace older, and, the order is, Codex, Chapter Approved 2017, Index Imperium I.
If the option is in the Codex, use that.
If the option is not in the Codex, but is in Chapter Approved 2017, use that.
If the option is not in the Codex, nor CA 2017, use the Index.
If the option is in CA 2017 and the Index, use the most recent rules, as in, CA 2017.
If the option is in the Codex, CA 2017, and the Index, use the Codex.
Rules order: Codex, Chapter Approved 2017, Index Imperium I.
When CA 2018 comes out later this year, it will, at times, be the more recent rules than the Codex; use the most recent, to the earliest release, in order.
Codex.
Chapter Approved 2017.
Index Imperium I.
hmmmm intersting line of reasoning. I think you are refering to the Stim Injectors for T'au and it makes a bit of sense. I would argue though that one is a piece of wargear and the other a whole unit.
Still with this prescedent it is a good question to FAQ.
