Glute Posted August 28, 2018 Share Posted August 28, 2018 GMDK has 5 attacks base and has 1 Dreadfist and 1 Greatsword. 1. Does he get to attack with both melee weapons 5 attacks each? 2. If NO - can you split the 5 attacks between the weapons? i.e. 3 attacks with Sword to target 'A' and 2 attacks with Dreadfist to target 'B'? Link to comment https://bolterandchainsword.com/topic/349937-gmdk-dreadfist-greatsword-in-melee-question/ Share on other sites More sharing options...
jeffersonian000 Posted August 29, 2018 Share Posted August 29, 2018 GMDK has 5 attacks base and has 1 Dreadfist and 1 Greatsword. 1. Does he get to attack with both melee weapons 5 attacks each? 2. If NO - can you split the 5 attacks between the weapons? i.e. 3 attacks with Sword to target 'A' and 2 attacks with Dreadfist to target 'B'? It’s option 2, but you will never need to use the Fist when you have a Sword or Hammer. SJ Link to comment https://bolterandchainsword.com/topic/349937-gmdk-dreadfist-greatsword-in-melee-question/#findComment-5155929 Share on other sites More sharing options...
Glute Posted August 29, 2018 Author Share Posted August 29, 2018 GMDK has 5 attacks base and has 1 Dreadfist and 1 Greatsword. 1. Does he get to attack with both melee weapons 5 attacks each? 2. If NO - can you split the 5 attacks between the weapons? i.e. 3 attacks with Sword to target 'A' and 2 attacks with Dreadfist to target 'B'? It’s option 2, but you will never need to use the Fist when you have a Sword or Hammer. SJ Thanks -- I thought that was the case and yea.. I only use the sword. Link to comment https://bolterandchainsword.com/topic/349937-gmdk-dreadfist-greatsword-in-melee-question/#findComment-5155956 Share on other sites More sharing options...
