Questions about Lias Issoden
Recently I've been considering starting up Space Marines again, and I'm leaning heavily towards Raptors. Lias Issoden just seems too good of a chapter master to pass up.
Before I do start buying more plastic crack, I mean models, I have a couple questions about Issoden:
- Seeing as how he doesn't have an actual model, what are your recommendations for how to kitbash him into existence?
- With his crazy deep strike rule, does that make the additional 3 units all one drop in deployment? Or are they still all separate?
- What would be some good units to drop in with Issoden? I'm thinking a squad of Sternguard at the very least. But I'm not entirely sure where to go from there with the other 2.
https://bolterandchainsword.com/topic/349951-questions-about-lias-issoden/
So from what I'm understanding is his deep strike is basically just a way to get non-deep striking units that ability. So still separate drops, but they deep strike in (so long as they come on with Issodon). Am I correct?
Also, why would I drop in Vanguard Vets in with him as one of the 3 drops? I give them jump packs and they can do that already. Unless you're saying no jump packs?
I am fairly certain Lias does "condense" 4 drops into one essentially.
Like was mentioned, his ambush ability does not circumvent the Deep Strike beta rules
SFTS does
So if the unit is range-intensive, you are probably going to want to take SFTS on the unit.
If you'rein no rush to get him done, the Space Marine Vigilator Forge World showed at WH fest Europe looks like a great proxy for Lias.
He has the Sniper Weapon, Sword, and wears a armour irnate enough to be a CM but not too ornate for the Raptors pragmatic tastes.
Also he has a swooshy cape you can paint up to be a Camo cloak.
And the entire backpack is covered in ammo/gear pouches, including a holstered bolt pistol. Will buy one when out, that would be my 4th Lias model...
