domsto Posted September 4, 2018 Share Posted September 4, 2018 As the next big FAQ is imminent and it is more than safe that we will get some beating couse of the Loyal 32. I read a lot of ideas how to fix this and in most cases it couse some serious Problems for Guard, like a prise hike for the humble Guardsmen or something like that. When i look at Consripts and how they destroyed them i am a little consern that the same will happen to our most basic Infantry. Instead of nerfing Guard to the Ground i think it would be better to buff pure Armys or something like this. What do you think? Will Guard be once again punished for a Crime they didn't comit? Any Ideas how to Fix the CP Battary? Link to comment Share on other sites More sharing options...
sairence Posted September 4, 2018 Share Posted September 4, 2018 In order of what I consider most to least useful: -Make Grand Strategist and similar traits only work on generic and Armykeyword-specific strategems -Make it so the Warlord HAS to be from the largest army keyword/biggest detachment pointswise -Make separate CP-pools based on army-KWs that can then only be used on that kw or on generic strategems. Combining the first two would probably solve the worst excesses. The last one would be less practical in mixed forces. I hope they learned from the conscript debacle and try to go for a fix to the fundamental problem instead of beating on Guard some more. I remain pessimistic in that regard though. Link to comment Share on other sites More sharing options...
duz_ Posted September 4, 2018 Share Posted September 4, 2018 In match play CP's generated by detachments can only be use for their own Faction (sub Imperium Level) Gained/ Regenerated CP's can only be done for the faction with the same keyword and used on that faction A bit of a pain to track, but will solve the guard CP battery at once... Link to comment Share on other sites More sharing options...
Colonel Bindoff Posted September 4, 2018 Share Posted September 4, 2018 I think ‘a bit of a pain to track’ might be an understatement Duz! On a side note, how many Aquilae did Kurov make?! The guy must have spent literally his whole career stuffing servitor bits into wildfowl Link to comment Share on other sites More sharing options...
duz_ Posted September 4, 2018 Share Posted September 4, 2018 I think ‘a bit of a pain to track’ might be an understatement Duz! But is it really? Most tournaments are 2000pts, which means max 3 detachments and there for max 3 factions, more likely 2. So you have to use different colour dice to track CP's and which you used on what. Doesn't seem any more complicated than tracking multi wound models and profiles or orders and stratagems and everything else we track in a game. The more I think about it, the more I think that its a poor cop-out on why its shouldn't be adopted and the simplest way of fixing it without nerfing everything particularly guard Link to comment Share on other sites More sharing options...
WarriorFish Posted September 4, 2018 Share Posted September 4, 2018 I think it's a good idea, perhaps alternates could be limiting Stratagems to a single main Faction? At the moment allied lists have no drawbacks which is silly, but at the same time it shouldn't be excessively penalised - CPs/Stratagems seem like an easy way to do this. I'll be glad to see the end of Guard CP batteries so long as the solution doesn't mean hurting Guard directly. I'm yet to be fully convinced "New GW" knows exactly what it's doing but as always I shall wait and see Link to comment Share on other sites More sharing options...
Colonel Bindoff Posted September 4, 2018 Share Posted September 4, 2018 Maybe; I’m just mindful of the potential for opponents getting ‘confused’ or accidentally putting CP counters in the wrong pile! I agree it is the best way of solving the problem though Link to comment Share on other sites More sharing options...
Tirak Posted September 4, 2018 Share Posted September 4, 2018 Separate CP pools I think would go a long way to curbing Guard Battery Lists, and I'd welcome that change. I honestly get annoyed with lists that bring a token guard force just to power the stratagems of other armies as it leaves us vulnerable to nerfs for abuse, when Guard armies aren't the abusive ones. Conscripts and Commissars, two of our most iconic units got utterly gutted because other armies tossed in a minimum battalion to farm for cheap bodies and cheap CP. The CP cost rework was of course meant to curb this by making the Battalion more attractive and encourage you to run your main faction, but that just made Guard CP Battery even better because for the same cheap price you could get even more CP. If GW doesn't take that route in the upcoming CA, then I predict they'll be bringing the nerfhammer down more on Guard because they don't mind going after a relatively "minor" faction if they can keep selling Space Marine kits. Link to comment Share on other sites More sharing options...
FallenSoldiers Posted September 4, 2018 Share Posted September 4, 2018 I’d be happy if Strategist only let you regen points spent on AM stratagems. The Aquila getting you 1 back isn’t bad, but when you’re using a 3CP knight stratagem and you get 2CP back... that’s abuse. Sadly I think the Guard are in for another beating with the nerf bat, potentially right out of existence. Link to comment Share on other sites More sharing options...
Colonel Bindoff Posted September 4, 2018 Share Posted September 4, 2018 (Snip) Sadly I think the Guard are in for another beating with the nerf bat, potentially right out of existence. Report to the commissar at once, lest your lack of faith in the might of the guard rubs off on the rest of the barracks! We may take a beating; our soldiers may increase in points to reflect their courage; the enemy may bring a nerf bat hand crafted by Lord Vulkan himself; but there will ALWAYS be men and women of the guard ready to march into the hell of unjust rules edits with fire in their hearts, knowing that they command the awe of every other factions’ players, who just don’t have the steel to play imperial guard. Link to comment Share on other sites More sharing options...
FallenSoldiers Posted September 4, 2018 Share Posted September 4, 2018 Oh no! Not ME persay! I love the Guard! I just think when arent going to be seeing them as part of many high end tables at top tier events after this FAQ! GW... please prove me wrong!! Link to comment Share on other sites More sharing options...
domsto Posted September 5, 2018 Author Share Posted September 5, 2018 but a point hike of a Guardsmen would be the absolut worst that can happen! It wouldn't change anything for the CP Farmers because they will still be the cheapest way to get CP but for a pure Guard list this will be a heavy nerf. Guard is already the worst Horde army out there. Link to comment Share on other sites More sharing options...
domsto Posted September 5, 2018 Author Share Posted September 5, 2018 In order of what I consider most to least useful: -Make Grand Strategist and similar traits only work on generic and Armykeyword-specific strategems -Make it so the Warlord HAS to be from the largest army keyword/biggest detachment pointswise -Make separate CP-pools based on army-KWs that can then only be used on that kw or on generic strategems. Combining the first two would probably solve the worst excesses. The last one would be less practical in mixed forces. I hope they learned from the conscript debacle and try to go for a fix to the fundamental problem instead of beating on Guard some more. I remain pessimistic in that regard though. I Like your Idea of splitting the CP pools after Keywords That would solve the abuse Problem at once but will make it still possible to mix Factions for a Thematic List. I realy Hope GW will be this forward-looking Link to comment Share on other sites More sharing options...
-Nemesis- Posted September 5, 2018 Share Posted September 5, 2018 You can only use stratagems from the Warlord's codex? Custodes/Angels/Knights will be reconsidering the Guard CP batteries if they have to give up all their stratagems for it. Link to comment Share on other sites More sharing options...
H311fi5h Posted September 5, 2018 Share Posted September 5, 2018 What about lowering the CP for all detachments, but giving some extra CP for detachments from the same faction as your Warlord. For example two AM battalions and one AM spearhead could be (3+2) + (3+2) + (0+2), while AM battalion (with AM WL) + BA battalion + Custodes Supreme would only give (3+2) + 3 + 0. So you would "pay" 4 CP for souping in this scenario. Link to comment Share on other sites More sharing options...
KhorneHunter57x Posted September 5, 2018 Share Posted September 5, 2018 In match play CP's generated by detachments can only be use for their own Faction (sub Imperium Level) Gained/ Regenerated CP's can only be done for the faction with the same keyword and used on that faction A bit of a pain to track, but will solve the guard CP battery at once... I don't think it'll be a pain; in fact, I think it would be a simple and effective solution that rewards 'pure' forces. Two or three sets of CP-tracking dice instead of one, or an extra set of tally marks on a sheet of paper. A tiny bit more book-keeping for mixed forces, and no change for pure ones. Maybe; I’m just mindful of the potential for opponents getting ‘confused’ or accidentally putting CP counters in the wrong pile! I agree it is the best way of solving the problem though I don't think it'll result in too much more confusion or accidents (legitimate or otherwise...) than the current system. Link to comment Share on other sites More sharing options...
Tirak Posted September 5, 2018 Share Posted September 5, 2018 but a point hike of a Guardsmen would be the absolut worst that can happen! It wouldn't change anything for the CP Farmers because they will still be the cheapest way to get CP but for a pure Guard list this will be a heavy nerf. Guard is already the worst Horde army out there. We're actually not. 'nid Hoards are in a bad spot, there's a reason why all the 'nid lists that have been competitive have been some form of Flying Hive Tyrant (leading to the stupid datasheet rule) or Carnifex spam. Close friend of mine runs 'nids, adores his hoards, but when it comes time to play serious, the Gaunts go in the box, and the Carnifexes come out. That isn't to say there aren't other aspects of the Tyranid army that aren't very good, just that when they try to hoard like in their fluff, they get stomped. Link to comment Share on other sites More sharing options...
Shamansky Posted September 5, 2018 Share Posted September 5, 2018 I see too many defeatist speculations here. That's ignominious, gentlemen. What if your troops will see this? Our duty demands we stand firm with the faith in our hearts, weapons in hands, holding our heads up high and be ready for the worst. If we should inevitably die, then let's at least die with honor. Link to comment Share on other sites More sharing options...
duz_ Posted September 5, 2018 Share Posted September 5, 2018 Well I do see many good suggestions in here. I would suggest we take the time to contact GW with the suggestions to CPs and raise the concern of nerfing IG is more of penalty to actually guard players as opposed to those who take them for CPs alone. 40kfaq@gwplc.com :tu: Link to comment Share on other sites More sharing options...
domsto Posted September 5, 2018 Author Share Posted September 5, 2018 a good idea duz_ i will send the suggestions to GW. Maybe they will listen this time Link to comment Share on other sites More sharing options...
Shamansky Posted September 5, 2018 Share Posted September 5, 2018 Well that's the spirit! Link to comment Share on other sites More sharing options...
Beams Posted September 5, 2018 Share Posted September 5, 2018 Warlord should have to have the highest LD in your army, like they used to be. Link to comment Share on other sites More sharing options...
domsto Posted September 5, 2018 Author Share Posted September 5, 2018 Warlord should have to have the highest LD in your army, like they used to be.That wouldn't change mutchA AM Battalion would still be the most point effectiv way for soup armys to get more CP Link to comment Share on other sites More sharing options...
Beams Posted September 5, 2018 Share Posted September 5, 2018 Warlord should have to have the highest LD in your army, like they used to be.That wouldn't change mutchA AM Battalion would still be the most point effectiv way for soup armys to get more CP It would limit the warlord trait to pretty much guard only, since guards highest generic leadership is 8-9, so Space Marines would generally beat that. At the very least, it'd get rid of Guilliman/Knights and guard. Link to comment Share on other sites More sharing options...
robofish7591 Posted September 5, 2018 Share Posted September 5, 2018 What if you had to choose a faction and only that faction would be allowed to have chapter tactics, relics, or stratagems? For example, if you took a list with guard, blood angels, and a knight, you would have to pick one of those to be your faction. So if you chose guard, you could still take blood angels and a knight, but they would lose access to their stratagems and chapter/household tactics. If you chose blood angels as your faction, you could still bring guard for bodies, but you wouldn't get all the extra bonuses. Link to comment Share on other sites More sharing options...
