Death watch master conversion
turned my artemis into a stock watch captain with Jump Pack or can use it as Watchmaster.
- had him floating at first, hence the leaning and cut foot -
(never finished him cause i like to put things together just to take them apart and revise things)
- dry fit test runs btw, excuse the madness on him -
I love that spear delta.skies
Where’s it from?
its really a frankenstein due to an eyeball error, if you notice, the handle on the top part is different from the bottom.
- top part of the handle i can not remember -
- bottom part is the primaris chaplain handle with the crozius -
- blade is the a long blade from stormcast eternal -
- ork skullz as part of the hilt -
- purity seal cause i cut a bit of the hand, so there was a gap, couldnt pin it without destroying the handle so it helped hold in place -
