Squiggoth, Gorka/Morkanaut counts-as and size
Kierdale
Does anyone have a squiggoth or gargantuan squiggoth? About how big are they?
I wondered if any of the Seraphon dinos might be substitutable, with a built-up Howdah...or even two dinos with a structure on/between them?
EDIT:
I checked myself...
YouTube is a wonderful thing!
This thread this turns from question into source :)
Gargantuan Squiggoth:
13” long
8” high to top of the howdah
6” high to the top of the shoulder
5” wide at the shoulders
Normal Squggoth:
6.25” long
4.35” high to the top of the howdah
3” wide at the front paws
And the dimensions of a Gorka/Morkanaut:
Height 13cm
Width 15.5cm
Length 12cm
Now to search for measurements of those Dinos (Seraphon ones as I want to keep it all GW if I do ever make one)...
Troglodon/Carnosaur:
L:24cm = 9.4”
W:9.5cm = 3.7”
H:16cm = 6.3”
Dread saurian:
Dread Saurian, here it is:
“It's 14inches from his head to the furthest part of his tail. Bear in mind it bends round so straightened out would be longer.
His tallest spike is 7 inches from the ground.
His body is about 3 inches thick at it's thickest.
Back leg is 4 inches tall, front is 3inches.
Head is 3 inches long and 1.5 inches wide.”
Stegadon (with Howdah and antennas)
H,L,W: 12cm, 14cm, 6cm = 4.72”, 5.5”, 2.4”
Bastiladon with Solar Engine:
H,L,W: 8cm, 14cm, 7cm = 3.1”, 5.5”, 2.8”
You’re welcome.
A thought:
since in 8th edition vehicle facings don’t matter, the length and width of a counts-as-whatever are interchangeable. So if I get two Bastiladons and build a ruddy big howdah-castle stop/between them, so it’s 13” wise, 5.5” long and 8” to the top of the monstrosity(:D) it could
A. be’ a Gargantuan Squiggoth.
B. be a huge centrepiece model.
You’re welcome.
A thought:
since in 8th edition vehicle facings don’t matter, the length and width of a counts-as-whatever are interchangeable. So if I get two Bastiladons and build a ruddy big howdah-castle stop/between them, so it’s 13” wise, 5.5” long and 8” to the top of the monstrosity(:biggrin.:) it could
You madman. I love it :D
Guessing your Snakebites are gonna get a Squiggoth/Gargantuan Squiggoth sometime soonish then? ;)
You’re welcome.
A thought:
*yoink*
I was poundering what to build for a centerpiece. I reckon a Stompa would make for a handy howdah, a ruined one salvaged as an idol on lashed together metal girders
